Love the IOT
Thank you very much!
I still think these could be improved by allowing download of the archive audio files though...
Excellent serie. Thank you.
Thank you Brian and Alex
No work with smart grid
is it a successful design?
present a case study
thank u brian. when will be the next session on embedded systems?
Thanks,Brian.  Very informative and good food for thought.  Looking forward to a 102 version.
Hi all
Paul O'Brien, ABB, Australia developing a smart grid solution
Thanks Brian and Alex; Great week session
Well, time for me to go. Thanks for your questions Jeffrey.
Question is if you want something that cannot be read from outside the processor.
Many systems contain one of these already in their Ethernet ID.
It would be wrong for them to dictate how something is implemented. Not all vendors may have the necessary hardware capabilities built in and this would be the standards group doing the limitation. They cannot that, they have to allow the industry to do the elimination if necessary.
OK, is see that. I'm thinking of hardware more like a fusable register to hold a value as the basis for a root-of-trust.
As an exmaple - maybe you want to measure the power draw of the system before you actually load anything. That way you can detect a HW configuration change.
But conceptually you just need to implement the TPM spec. I'm not sure if the Trusted Computing Group spec for TPM mandates the TPM be implement in hardware or have hardware support. But I may be wrong.
OK - yes, there is very low level SW but also a lot of HW support for monitoring the system characteristics. You dont want to leave this to SW I suspect.
For trusted program it is sort of BIOS level software, so not sure if you would develop it in the same way. It has to run directly on the HW without OS or virtualization support.
Trusted Platform Module (Slide 9)
Do you mean trusted program?
Is it possible to implement the TPM in software?
In that case, I have not heard of such a usage of AMT with SCADA. But it may exist.
Intels's link - http://www.intel.com/content/www/us/en/architecture-and-technology/intel-active-management-technology.html
So AMT is the seperate power domain and KVM access.
Gotta jump off early today folks.  Its been great - you all have my contact info.  Let's stay in touch.
Right I'm just not sure what AMT is reffering to. It can't be Alternative Minimum Tax.
@Juan - it was in the reference implementation but not sure if deployed.
AMT - Active Management Technology
I meant whether AMT has been used in actual SCADA applications.
MMM. Not sure what is goingon. texts stopped getting through
And when we react we tend to fix the symptom not the cause.
As a society we tend to be reactionary. After we have been hit, we react and put better systems in place. Does anyone do backups before they have lost data? Does anyone install security software before they have been infected?
Juan, what did you mean by AMT?
Thank you Brian and Alex! The sessions were very informative.
@Juan - I think the biggest problem today is complacency in all industries that are not subjected to regulations. It is a cost that people do not want to eat.
@Juan - that was in response to your earlier question .
Thanks Brian and Alex, and EETimes, excellent presentation
@Juan - I believe so, but not 100% certain on that.
Brian, in your opinion, are the main security issues in industrial systems today, the management of a wide range of keys, or are there other infrastructure (perhaps) architectural issues as well?
would like to see into to embedded linux system webinar like these in future and we can do simulatiion with virtual lab hardware/software
@Embedded Guy - Thanks for the comment and yes it was high level, but many of the topics we talked about could be a whole course on their own. I hope it sends people in the right direction to get more relevant information.
Good point - thanks
@mclaus - I woyulkd suggest, just as we do with credit cards, that an order and the card information are sent separately. That way at least two parts of the system have to be comproimised before damage can be done.
Thank you Alex and EEtimes team
Thank you Brian and Alex for this great five day session.
I appreciate the heads up on this Internet of Things concept.  I realize it was a high level discussion, but it is nice to know that it is going on before it all hits the market (surprise!).  Thanks Brian and Alex for great information!
Thanks for a good set of lectures.
thank you Alex nd Brian
thanks to eetimes team also
@Jeff - many people think it was a large country that was to blame.
Brian / Alex - thanks for putting this together.  Very interesting.  Hope we do more of these.
I have learned a lot on this Class.
Thank you Brian and Alex.
thank you brain & alex
Thanks Brian and Alex. It's been a great week. See all next time.
Thank you for the lectures Brian, very informative!
There is - but since update in basically an automated process, we have essentially embedded a password into the code - a very bad practice.  It is encrypted and known to only a few in our organization, but still it is probably vulnerable to being hacked if somebody were to work at it hard enough.  We are planning to change to a dynamically generated key that will be provided via a newwork connection back to our central service organization - but we don't have that infrastructure quote ready yet.
Thank you Brain and Alex for the presentaion.
Relevant Intel Intelligent Systems Framework (ISF) links:
Intel Intelligent Systems Framework page: http://www.intel.com/content/www/us/en/embedded/intelligent-systems.html
Intel Embedded Design Center (registration required):
https://www-ssl.intel.com/p/en_US/embedded/login?
Is there an authentication protocol in the update API?
Stuxnet is very complex and bears the marks of being done by a larger group that had motives beyond simple credit card theft etc. Do we have any idea who they were?
There are ways to re-register the process code with the boot process.  During updates, there is an API that get exercises to re-register the new process code.  Updates to the boot image contain process registrations already.
Oops, I meant AMT
Has IMT been used with SCADA?
@mclaus, how do you deal with updates? Update both the bootcode and process code?
We ensure that any code that runs on our system is known.  The boot process gets the boot image from a known, encrypted, secure source.  Any process code that is run after boot must be registered with the boot image and it;'s image much match the one that was registered.
In my world "CIP" is the Common Industrial Protocol.
Right now, its usually a propriety standard in a license frequency. Very small amounts of data.
@mclaus - Thanks for the security example!
How does the Smart Meter work?
How does it  trasmit it's DATA?
Yes - we sell the 'the ability to treat patients' with our products to our customers over the web.  They pay, we download a certain number of treatments into the system to allow them to deliver the treatments.  Often we place the equipment of free, but make money by selling the tretments.
A group in China learned to hack the code that allowed download of treatment, as was selling that hack to our customers.  Big problem, but we did finally get it resolved.
Most companies do not brag about their security vulnerabilities.
Rockwell is also working on the SmartGrid, in standards and in project space.
@Jeffrey.Fortin FYI: Brian Bailey mentioned yesterday that he is aware of the missing slide numbers.
Working to improve the Smart Grid.
Jeffrey Fortin
Director for Industrial, Energy, Medical, and Intelligent Systems
Wind River
1420 Celebration Blvd Suite 200
Celebration, FL 34747
jeffrey.fortin@windriver.com
Unanswered question from earlier in the week:  Are there any emerging/existing standards in the area of Management?  Brian was going to check into it.
Not working on smartgrid
Sustaining Engineering Project Leader
Titan Logix corp
Michael Claus
System Architect
Alcon Research, Ltd.
15800 Alton Parkway
Irvine, CA  92618
michael.claus@alconlabs.com
R&D Engineer HW/SW @ NXP Semiconductor
Hi There from Toronto, interesting Embedded Arrow event in the city yesterday J
Jeff Rochow
Software Architect (Advanced Technology Group)
Rockwell Automation, Inc.
1 Allen-Bradley Dr.
Mayfield Hts. Oh 44124
good morning all from chilly Edmonton, Alberta
embeeded system really very interesting area  and skill to master either window embedded or linux or anyone tried on Mac ?
Good evening from Kuwait little coolish tonight
JUst use the PPT Numbers on the bottom Left corner of the PPT.
Hi Folks.  It never rains in Southern California..... except today....
Morning from St. Louis!
And yes today in Portland it is rainy, no sunny, no rainy, no - well it just cant make up its mind.
Yes - I hope it is not at 2pm eastern! I am ready for a 9:00am Pacific start!
@Jeffrey - yes sorry I did not have time yesterday to get them fixed and have them put the new deck up. I will make sure I use the titles.
Brian, just noticeing that there are no slide numbers on today's deck.
Good morning one and all!
Hello from Orlando where it's 75°F and sunny
@ awolf58; Is it 2pm not 12:00 PM?
Good morning everyone. Lots of stuff crammed into today's session. I will need to talk fast!
Good Morning from STORMY San Sose, CA.
It's 60°F and a High of 62°F.
2PM Eastern!! No wonder! will be back then..  BFN
Be sure to click 'Today's Slide Deck' under Special Educational Materials above right to download the PowerPoint for today's session.
The streaming audio player will appear on this web page when the show starts at 2pm eastern today. Note however that some companies block live audio streams. If when the show starts you don't hear any audio, try refreshing your browser. The player "like" Firefox better than IE.
Are we not on today??
Greetings from Gilbert, AZ with overcast 46F
good morning to you too, from Rockwell Automation in Mayfield hts ohio, where it's a sunny 41F.
milind_vlsi
Tim R Johnson
dt_hayden
dt_hayden
