Counterfeiting:  In my current job, not such a big deal...
In my old job, it was a big deal - we were a DoD "trusted foundry"
Anti-tamper was a big deal.
Blogger
Looking forward to those radiation resistant discussions in next hour...
Rookie
I have not used either of those design environments.
Rookie
look forward to the fridays presentation.
Rookie
Nice presentation.  bye all.
Rookie
Vivado is an amazing tool that does alot on its own.
Rookie
very big concern about counterfiting.  5
Rookie
I've done some basic design in FPGA's
Rookie
Thanks to advanced simulation tools ( a lot of which are free now) debugging has progressed tremendously.
Rookie
Debug takes more time as designs are more complicated - but the tools have evolved tremendously to help.
Rookie
No use of TotalRecall or GateRocket
Rookie
hello all from Edmonton, Alberta
Rookie
Missed the PART 4, becuase of Semester End Exam. But now I am going through that.
Feels good.
Rookie
Good Morning. I can't login yesterday. Maybe the class was Full and it won't let me in.
Rookie
Thanks Max and Brian; excellent presentation
Rookie
Glad the audio is still here for us slowpokes! Darn Work!
Rookie
Here's hoping no internet problems tomorrow.
Rookie
Thansk Tmka -- we're all chatting furiously over there -- look forward to seeing you there
Thanks for the link Max. I'll join gladly.
Rookie
I really appreciate your joing me here toda yand all the kind words -- tomorrow is going to be really good because we'll be covering all sorts of interestng things
In a few minutes I will have to leave now to host the weekly live chat we have on All Programmable Planet (actually I'm already there -- I have multiple monitors and keyboards -- so I'm now in both chats -- my head hurts) -- it would be GREAT if you could join us -- just use this short-form link -- http://bit.ly/XXqPG0
@Dave: Do CPLD's usually have non-volatile cofigurations?
Yes
@cryptkicks: The problem is to STOP me talking -- I coudl waffl eon fo rhours about almost anything (sometimes I even know what I'm talking about :-)
ok I think I'm getting this now. Thanks Max!
@Dave: Does the CPLD have a permanent flash based configuration?
Ah, there was a question in there :-)  The CPLD will almost certainly have a non-volatile configuration -- it might not b eFlash-based, it could be EEPROM (very similar) or fusible link or antifuse-based ... but these days probably Flash-based is a safe (or good) bet
Thanks Max , for the insights.
Rookie
@Dave: There is a CPLD on my target board that I think controls the SD flash config process.
Thanks for sharing :-)
@Dave: The internal config engine controls everything irrespective of the mode (serial/Parallel, Master/Slave, or JTAG) ... all of the config data passes through the config engine on its way into the confic cells
@erhk: Zynq will be able ro drive cheap LCD display?
I think with the Zynq you can drive just about anything. You can configure some of the programmable fabric to drive an HDMI display if you wish. One of the things folks are doing over on All Programmable Planet is creating their own soft cores to drive VGA displays -- I'm sure there will be soft cores available to drive cheap-and-cheerful LCDs
I am currently configuring from JTAG but want to use SD flash config as well and for permanent power up config when the design is finalized.
Max,
Currently, I am using Spartan-3 FPGA and Display Module but Display module is expensive. Is Zynq will be able ro drive cheap LCD display?
Rookie
@bobo -- the problem is no different working with embedded microcontroller systems.  If there is no trace and debug capability, no access to source code, you have very limited observations to make.  Unless the debug was built-in, you are out of luck.
Rookie
ok so the FPGA internal config engine will control the whole config process when in master mode.
@dave: serial with FPGA as master means that the FPGHA is in charge of loading a serial bitstream from the outside world (usually a Flash memory chip). Parallel with FPGA as master is the same, but using a multi-bit-wide bus
Parallel with FPGA as slave might be using an external MCU to load the configuration data into the FPGA... etc
I cannot get access to the ppt... :(
Rookie
Often cause me to pull my hair out.
Thanks
Rookie
@Dave: Master refers to the devuce that's in charge -- slave refers to the device that is controlled by the master.
ok maybe the master/slave just refers to the clock generator for data transfers?
@Bobolicious: I think you have a big problem there -- if you don; tknow what's inside the design and have no way to access its registers, then you really are left just looking at the signals going in and coming out of the FPGA
Thanks for the http://bit.ly/XXqPG0 short link, Max
Rookie
@Throcko: Re accessing the archive -- I think you just come back to th emain course window listing all the sessions and click on the session you want -- if we've already done it then it's archived -- if we haven;t done it yet (like tomorrow's session) then it will send you a reminder...
I work with units that have many FPGA's used in the circuit designs. From a technicians perspective, not knowing exactly the designers programming concepts, is there a good way to go in and debug FPGA issues. I find the only way to look at inputs and outputs on a logic analyzer but would like to know whether there is a better way to troubleshoot FPGA circuits when often the design engineers are no longer around?
Rookie
I would like to know more about slide 4 basic config modes. Eg. if not in JTAG only then you can still program from JTAG as well as serial/parallel AND what is meant by master and slave?
Thanks Max,
I will hear you tomorrow.
Rookie
Thanks Max.  After 28 years of designing, I'm amazed at how the basic concepts have stayed the same, and the tools have gotten so much better!
After this (at the top of th ehour) I'll be bouncing over to host the weekly live chat we have on All Programmable Planet -- it would be GREAT if you could join us -- just use this short-form link -- http://bit.ly/XXqPG0
What is the link to the All Programmable Planet chat with Max ?
Rookie
@Za: Thansk yo usom much - -the best we can hop eto do in these talks is introduce the fundamental concepts - -but knowing something is out there is 1/2 the battle
I too would like to see how to access the archive.
Rookie
Thanks Again for carrying on guys ...   technical diffculties happen ... especially on the days when the schedule is a little more constrained.   that's Murphy's Law ... right ?!   Have bookmarked the AllProgrammablePlanet.com
Best To you
Rookie
Awesome, Max thank you for another great presentation.
Rookie
Max,
Rookie
@eexwd2 : download working for me.
Rookie
Please tell us how to access the archive for this session
Rookie
Can anyone download the ppt? It keeps giving me error messages...
Rookie
Has the talk finished? I cannot find the link to attend the course...
Rookie
@Pedro Salazar... we had technical problems on the live portion and came back on at Slide #16.
Rookie
finally server is up
Rookie
Our server had issues today also.
Rookie
I was unable to attend from the begining due to the techinal dificulty. i will have to check the archive  later.
Rookie
missed most of this session
Rookie
Yes me too - just logged on now
Rookie
It didn't work in St. Louis MO either until just now. I guess I'll just listen to the archive version (and skip the live chat). I'm happy that that's available. Thanks again, guys.
Rookie
I was not asking which slide.
Rookie
ok, i will watch the archived version
Rookie
now in the slice 18?
Rookie
Just now able to log in...interesting technical glitch.  I was trying the website every 2 or 3 minutes and on one of the tries I got a picture of a baby kitten (??????)
Rookie
technical and network issues going on here in Central Texas
Rookie
@boxerboxer... we should wrap the audio portion within 5-10 minutes and then dive into the chat session.
Rookie
Again, our apologies for our server problems this morning. This session will be archived immediately after the live portion, so you can catch up from the beginning of Max's presentation.
Rookie
Brian, what time did the presentation start, and what time do you expect it to finish, rougly?
Rookie
Well fially got here
CEO
I guess It's better to go through this lecture offline after it is archived. Wasn't able to join due to the technical problems.
Rookie
Holy cow!..... I've been tryig to get in for 40 minutes .... Only now, just got in!
Rookie
@moncho we're now on slide 16
Rookie
Which slide are we on?
Rookie
@crypticks... yes that was the case. The archive will be available immediately afterward so you can get caught up.
Rookie
wich slice coming now?
Rookie
Yeah, I couldn't post or do anything
Rookie
troubles with server/dns etc
Rookie
Good morning. Our apologies for the technical problems this morning!
Rookie
Web site just came up for me... been trying every minute or so since 11:58a ET.
Rookie
Thanks Max!  I am really learning a lot from the sessions.
Rookie
Morning from chilly Central New York
Rookie
Great slides, information and discussion.
Rookie
Moving from HDL to HLS, how can be the cost?
Rookie
Slides looking good Max.
Rookie
EE Life
Rishabh N. Mahajani, High School Senior and Future Engineer
Future Engineers: Don’t 'Trip Up' on Your College Road Trip
2 comments
A future engineer shares his impressions of a recent tour of top schools and offers advice on making the most of the time-honored tradition of the college road trip.
Max Maxfield
Juggling a Cornucopia of Projects
Max Maxfield
7 comments
I feel like I'm juggling a lot of hobby projects at the moment. The problem is that I can't juggle. Actually, that's not strictly true -- I can juggle ten fine china dinner plates, but ...
Larry Desjardin
Engineers Should Study Finance: 5 Reasons Why
Larry Desjardin
37 comments
I'm a big proponent of engineers learning financial basics. Why? Because engineers are making decisions all the time, in multiple ways. Having a good financial understanding guides these ...
Karen Field
July Cartoon Caption Contest: Let's Talk Some Trash
Karen Field
139 comments
Steve Jobs allegedly got his start by dumpster diving with the Computer Club at Homestead High in the early 1970s.
EE Times on Twitter
EE Times Twitter Feed
