Never used MIMO, only SISO.
Discipline is Training (eLearning & mLearning development)
Thanks Fanny; very informative lecture
really interesting talk! I am looking forward to the Bluetooth lecture!
That was a really interesting talk, thanks Fanny. Looking forward to your thoughts on RF testing.
Richard Osterloh, Windsor, UK. Embedded Firmware Engineer in Medical Devices
Thanks Fanny
acohenjr
note: The audio stream is not downloadable, it is archived and can be replayed as many times as needed.
Thank you Fanny for informative session.
Thank you all for joining!  I look forward to tomorrow's session.
Link to audio - Alex, can you please comment on this?
fanny please can u arrange a link to download a audio version of the session..
yes - the ACE supports both 3GPP and WiFi.  octoScope also has some channel emulation technology that i will mention in the next couple of days.
Thank you Fanny. Is the ACE able to give Cluster Models for both 3GPP and WiFi Models ?
Right - MIMO for base stations, SISO for clients (unless you can afford MIMO) - is typically best
The Azimuth ACE had a complete implementation of standards based channel models, most of which are based on cluster statistics.
...so from a plain hardware perspective:
SISO for wearable/battery powered devices
MIMO for base stations / access points
Right?
Does the Azimuth Channel Emulator emulate different Cluster Models from a single Test Equipment ?
please fanny can u arrange a link to download the audio version of session..that will be a great help
Thank You Fanny.
Thanks for sharing your expertise.
MIMO techniquest are chanbel dependent and must be dynamic.  The fast response to changing channel conditions is essential.
CDMA handles multipath using the 'rake receiver' techniques.  The widest CDMA channel is 5 MHz.  OFDM can span today over 100 MHz.
Regarding slide 5, fading is typically frequency selective, so some sub-carriers may be much weaker than others when the signal gets to the receiver.  The data is encoded in such a way as to be detectable even if some subcarriers are missing in the receiver.  Coding techniques are a very sophisticated part of the baseband DSP.
hi fanny ! can you arrange link to download the audio version of the session please its really helpful..
The APs can dynamically steer the beam to individual receivers and they can also create complex beams composed of multiple lobes - one for each receiver.
i have worked with MIMO in my undergraduation for presentaion of wireless power transmission..
I'd like to see OFDM vs CDMA compared vs the multipath problem.
slide 5, in OFDM, How we get the data in the subcarrier subjected to channel fading?.
Thanks
MIMO algorithms are usually 'secret soace' of the chipset manufacturers, and often their chipsets will work better with their own chipsets than with other chipsets.
Considering that there are many Techniques for MIMO, is there any specs detailing the efficiency/Tradeoffs for MIMO antennas in a Device for LTE and WiFi ?
Thank you. Very good presentation
Fanny, when there are multiple receiving nodes, do the APs dynamically steer the beam to individual receivers? Or is the beam steering adjusted only occasionally to give the best comprimise for all nodes?
What are the most basic algotithms for deciding witch is the better kind of use of the MIMO?
Is based in the number of packets transmited?
Is this usually implemented in some chipsets? What names have? The chipsets or the techniques to choose witch kind of use is better (time delay, different theads, ...) for the MIMO?
And thank you for the resentation
is there a good overview/book on this subject?
thxs for very informative presentation
Thank you very much. Good presentation. See you tomorrow.
is there any chance to download the audio of the session...
Thanks Fanny. It was very helfull
Thank you Fanny.  Your talk helped to clear up a few questions that I had regarding MIMO.
Thanks Fanny and Alex.
Thank you Fanny, great slide package
Thanks for all the great info on Mimo
thank you fanny.  great presentation.
Excellent presentation, look forward to tommorrow
@w6pdz Is that a ham call?  You're not in QRZ.
Thank You Fanny and Alex.
Thank you for today's presentation Fanny.
This was a good batch of information to consider. "Lots of Compromises"
Fanny, thanks for your presentation. Looking forward Bluetooth tomorrow...
with multiple receiving nodes, do the APs dynamicall steer the beam to individual receivers?
So, a single stream or multiple streams can be sent using multiple antennas? I presume there are algorithms to decide. Can you clarify this further?
Only used single antenna on product side.
i have not used MINO.  I am here to learn pluses + minuses.
No experience with wireless, other than mfg sample test kits to make wireless serial ports, which basically require no knowledge to use. Looking to attempt to incorpate wireless in my projects.
how does Slide 11 results compare with Slide 8?
Get to buy stack of 3 ea. VSA/VSG (i.e., LitePoint) WLAN testers for MIMO ;-) Use a single testing, sequentially, in factory testing
Working to measure MIMO throughput on LTE devices
Yes, worked with MIMO quite a bit on both licensed and unlicensed frequencies... it's definitely better than SISO, but it's not a panacea.  You still need a proper design, link budget, etc.
No expireince on any of them, just looking for a general overview
3x2 MIMO x 3 dual-band radios in flagshipo Motorola 11n Enterprise AP
OTA testing of MIMO is daunting/$$$
no MIMO or SISO experience
How is TRP and TIS measured for MIMO antennas ?
Want to connect RS 232 to slave units
Never work with MIMO.
Only used MIMO systems as normal user
I just worked SISO.
No experience in MIMO systems
Based on the arrows and definitions, aren't the MISO and SIMO diagrams on slide #9 reversed?
ideally a wavelength seperation...
printed antennas are less volumetrically efficient, and more suspectible to mnoise ingress/RX problems than 3D antenna structures. Product form-factor often driver of antenna choice (along with # of radio frequeinceis to support, i.e., smartphones & tablets)
Is there a minimum distance required for the separation of the antennas?
Senior Radio System Engineer now manager
Product Manager-Cypress semiconductors!
Sr. Program Manager,Microsoft. Interested in WiFi and Connectivity Solutions.
how well do printed antennas work compared to external
systems/communications eng, now patent attorney
Most chipsets (and PAs, LNAs, FEMs, switches, etc.) are 50-Ohm single-ended. Baluns often part of the mix. Impedance matching of these 50-Ohm parts/traces to antenna launch is main "trick" required...
Interest: Business Development, currently focused on TVWS, Silicon Valley
Modem FPGA design, microwave backhaul
Wireless Information Assurance Program Manager - A Component of the DOJ
embedded software.. communications
3 cell bands, Bluetooth, GPS, etc
She just mentioned matching circuit. I was going to ask about that. In the docs for a zigbee transceiver it just say "matching circuit" between the antenna and the chip. Could Fanny discus this a bit more than she already did?
Project Electrical Engineer for new product development at Philips Home Healthcare
Embedded SW Engineer
discipline: electrical engineer - technical translator for Rohde & Schwarz
Z match is challengling when you may have 4 to 7 bands using the same (fractal) antenna.
None at this time.
@embedded group:  Reload your browser. If no joy, try Firefox. If nothing, then it's possible your company is blocking live streams
HW/Embedded SW engr
reflections cause polarity changes
Q: I found that many cell towers share Tx and Rx path using diplxer. Is there any reason to share Rx and TX antenna except the cost?
HW/SW R&D Engineer.
unable to listen the audio
Mostly a general interest for MIMO - no current development
Not one in particular,...
None particulary, just looking for general knowledge
and, hit play a few times
If you lose audio try to reload the page
Hardware/Systems engineer for Satellite/Aerospace Company
EE, Patent Attorney, Chicago Area
No I'm getting no audio.
Hardware and R/D for wireless monitoring for renewable energy
no audio, can you do webex or go to meeting
So, is anyone hearing anything?
Is anyone hearing anything ? My audio stream just won't play
embedded software and hardware
Embedded Development - HW/FW/SW
lately mostly high power SMPS and Class D audio amplifiers. Here to learn
Are the multipath reflections cancelled by signal strength levels?
Hello from Turkey.
Embedded development of wireless monitor equipment
Embedded SW/HW Engineer
Did that yesterday.  Just restarted and it worked ok.
Embedded Controls Engineer
no audio here either
Doing more hardware & embedded systems. Interested in Wireless in relation to my hardware work
She was talking, but the stream suddenly stopped. Anyone else?
Signing in from Dallas, tx.
No audio stream again. Looks like archived is the only way I'm going to get to do this.  Thanks for nothing IT!
Software and hardware. General interest in wireless.
My first time here.  Am I supposed to see / hear something?
Thanks
We just lose audio?
Double E, Telecommunication
Embedded software, drivers
Software Engineer with hardware experience in Thailand.
Electrical Engineering, interest in wireless communication
Telecommunications Security Engineer
R&D design engineer in Broadcast and wireless comm
Hardware and software design. Currently working on wireless medical devices
Mechatronics/Robotics Engineering. Currently busy on  ELMs in a DIP-based setting.
Hines, checking in
Lead RF Design Engineer: VoWLAN, 11n & 11ac, tade-offs of # of streams vs. battery life/device size...
Good afternoon from Canada
my discipline: DoD aircraft systems R&D
Military Systems - System Test - No real design considerations at this time.
i have done my master's in microelectronics and i am interset in embedded system
Good morning from CA
Hello again, Same as yesterday, :)   Mostly hardware design but some software also.
Electrical Engineer designing a new car managment system
Tektronix application engineer
Electrical Engineer working in OSP Engineering and WiFi Design for Telecommunications Service Provider company
Im a Hardware Engineer working on smart metering
Sr. R&D Electronics Technician
Embedded Development, Land Mobile Radio
Hardware and software support
Hi from the Netherlands.
here we go, audio is up!
san diego here. I'm a lot wet behind the ears, so I'm trying to take in as much as possible. Work in test engineering for and aerospace company.
Greetings from South Africa.
Thank you for your link.
Greetings from Munich.
Hello everyone from Ecuador.
Hello From Toronto
Greetings from Bahston ... that's Boston if ya don't live here ... Count me as a hdwe/software engr with especial interest in low energy bluetooth ...
here's the link from yesterday's slide 19 on intelligent transportation systems:
http://www.bbc.com/future/story/20121005-building-the-crash-proof-car/1
Good morning from Sydney
Good evening from Iasi
Hello from New Jersey
Hello from Ireland...
Good Morning from San Jose, CA.
Freeze Alert this morning!
It's 33°F with a Hi of 57°F.
Hello from rainy Tennessee
Hello from frosty Silicon Valley ;-)
Rodney, North Pole Alaska (Near Fairbanks)
Hello from Finland...
Hello from San Diego.
Hello everybody, I am sherlock ni Vancouver.
I might not be around for the lecture.  Work is really calling, but can someone ask what is meant by 8 spatial streams for MIMO if each user is using 4 spatial streams and up to 4 users on MU - multi user? from the yesterday's lecture on slide 10?  What are those 8 spatial streams referencing? Or if any of you can answer.  I will look at this when I get back from the archive.  Thank you!!!!
Good Morning from New Jersey.
Good morning from Scottsdale
Yo Fanny, the slides look super
Morning! Slide 11 is not numbered
