Another great session. Lots of interesting content. I just wish the audio was available for download.
About to be involved with an academic embedded design project.
HW R&D, medical devices
HW/SW R&D Engineer
Good morning from San Jose, CA
Excellent class again
Thanks Fanny; excellent presentation. Missed two days back
Firmware Engineer in Medical Devices using wireless comms to sensors with 3G data backend
Thanks, good session
Thank you once again.
later
Good lecture!
Thank you Fanny and Alex
thank you all for joining and hope to see everyone back tomorrow
Thank you for the presentation and answers
we will look at some smaller anechoic chambers for higher frequency measurements tomorrow
there is gradient abxorber that's thinner and works well
for higher frequencies, such as 900 MHz and higher you may not need cones
yes - the cones are made of absorptive foam that kills reflections
The cones in the testing chamber are for killing reflexions?
tomorrow we will look at controlled environment test methods
Typically trying to measure over the air in the open air environment is difficult because there are many sources of signals and interference
another way may be to look with a spectrum analyzer and see if the spectrum looks like Wi-Fi or frequency hopping BT
to determine the wireless sytem used, you may try a wireless monitor (sniffer) or look inside at the chipsets used.
Thanks for your time Fanny
How can we determine what type of wireless system is used in a home appliance (ex. heating sensor communicating wirelessly with a heating device)
Thanks for the chipset comments!
Figuring out signal loss vs. terain, you may look into ray-tracing simulation packages.
We had good luck with TI as a chipset vendor with good support. Silicon Labs is also good.  When it comes to Wi-Fi, Ubiquity is a good vendor, but may be hard to get their attention for low volumes
thank you fanny very informative
Thank u all very much. It feels good to be part of this :)
For ad-hoc networks with mobile nodes - yes - you can lose coverage, so it's important for the network to be able to 'self-heal' and find alternate routs.
Tyhank you very much. Good presentation.
Good afternon to every one
New design to transmit RS232 data to multiple slave and master nodes.  Your overview has been moxt helpful.
Thanks
Good afternoon, everyone
Fanny, thank you for today's presentation, very informative.
 email psalazar@globalmed.com
@Pedro Salazar, North Scottsdale by Princess Dr.
As Fanny said, go the module route, if low volume. I've been in Enterprise 100k-1M/year radio, and support from all of the "big three" is rough, some off-load support for say $40k & ca. $200/hr. thru third parties.
Question - In an Ad-Hoc network structure, does the network have potential to loose coverage areas because of individuals moving locations?
Maybe some mention of chipset focus on consumer wireless (i.e., range vs. throught, and scalingof users/clients) vs. Enterprise/Industrial? Perfect business sense, but essential to be aware of this industry wide dichotomy.
Chipsets: are there any reccomendatins for vendors that are easy to work with with low volumes. (My experience is that Broadcom is VERY difficult)
@Pedro Salazar, Yes in Scottsdale
Lots of general test equipment at work
No RF test test equipment
No RF Test Equip yet
Tektronix MDO4104-6 Mixed Domain Oscilloscope  (1 GHz analog scope & 6 GHz spectrum analyzer)
for which frequency did you calculate the budget?
Test essentials:
power meters (peak sensor, given complex modulations), one-box tester (combined VSA & VSG, aka LitePoint, Agilent or R & S), VNA (for all detailed RF bard work), Spectrum analyzer, with freq. at least 3x radio band of operation (TX harmonics, spurs, etc.), wideband horn antenna & pre-amp.
Shield/screen rooms/boxes for most RX testing
are there any good free resources for figuring out signal loss based on terrain considerations??
No ownership of RF measuring tools
I have Spectrum Analyzer.
Personally I've got Spectrum Analyzer, Signal Generators, Measuring Receiver (High end sommunications test set), Network Analyzer.
Work only has a Spectrum Analyzer
Spec an and packet sniffer
spectrum analyzer and RF generator (agilent)
not much at the moment
Don't have test equipment.
Essentially "system integration" of radio modules- naive to expect "turn-key anything at 5 GHz ;-) FEM, LNA, switchs, filters & diplexers used to leverage reference design of chipset vendors. Modules lag chipsets by 1-2 years. Certain chipset vendors, i.,e Atheros, put the 5 GHz outside ther chipset/module, so somewhat forced to "roll your own." Difficult to get support form chipset vendors (understandably) if volumes are below ca. 1M/month. Antenna integration/matching, and conducted vs, radiated (OTA) RF performance are constant issues. Also, regulatory compliance is expensive & time-consuming, esp. if lots of countries involved, & 5 GHz much more "scattered" than 2.4 GHz.
I´m taking this course just to understand the basics of wireless. My plan is to use OTS products
looking at adding connectivity to devices for an existing std netrwork
Mostly user, no development for wireless
Embedded firmware on energy harvesting low power RF (EnOcean Alliance)
Partial turn key with a desire to possibly use alternatives to lower cost.
Due to (1) price and (2) extreme power sensitivity and (3) size constraints, I am looking at the chipset route.
No Wireless at this time.
Very much standards / architecture oriented (TVWS needs standardization to achieve economies of scale) but early in the technology cycle so also lots of tweaking under the covers
using BLE now, change to proprietary
Combination of both.  Depends on where we are.
I would be trying to use a Turn-Key setup rather than designing my own.
Trying to use an establish solution and trying to understand its operation.
802.14 mesh network for wireless communication with remote sensors
probably will be designing our own
we designed a protocol for MICS
I am doing a propietary implementation
I´ve used OSC over WiFi and I´m planning to use bluetooth to connect Android with microcontrollers
HW RF design: 802.11 abgn & BT in a VoWLAN radio & cutom, small, embedded antenna design  for a hand's-free, speech recognition "communications badge" used in health-care, hospitality and oil/gas/mining Enterprise verticals
CAN and Iso-CAN Transceiver.
No wireless project right now. Gathering knowledge.
embedded firmware.  Nothing wireless yet
LMS - Electrical Engineer, short range, high noise - little experience
hardware and software engineers for medical device
Sales of healthcare solutionsthat is dependent on communications
SW&HW R&D Engineering
No wireless projects at this time, but hope to play with it in the future.
No wireless project at this time
Wireless senor network (based on zigbee) for IoT
WSN for medical sensors
Mostly software, some hardware. Very little experience with wireless
Tektronix applications engineer
EE, technical translator for Rohde & Schwarz
embedded sw, communications
milenasukovic: Audio has started. It  is woking for me (after reload) on imac with 10.7.5 and safari.
Embeddes software, drivers
no audio on my macbook air os x 10.7.5, switched to this while updating my imac to mountain lion os, did the audio lecture start?
HW/SW R&D Engineering
@ZA you are in scottsdale too!
Hello from Ravensburg,
Mostly hardware with some firmware software.
Greetings from Halland
Academic embedded design
Military Systems - System Test
Electro-mechanical product development
Embedded systems consultant, hardware and software.
Current project is a wireless medical device
Hello from Vienna
Business Development ... currently focused on TVWS ... rural US and emerging markets overseas
Wireless data monitoring, Renewable Energy
HW & SW Tinkerer ~ Interactive Art
Hi - From CA, working on M2M Smart Metering with G3 GSM Module.  isidro
Hardware/software support-development
Warming up in Silicon Valley...
Good Morning from CA
An antenna question ... For LE Bluetooth to a cell phone or tablet, with the tablet standing vertically and my device flat (horizontal), what antenna orientation would you recommend?
almost there... no sound yet
Good evening from snowy Munich.
Another Bostonian here!
Good morning everyone, from Scootsdale, AZ
Good morning from Edmonton, AB
greetings from sydney
Greetings from Boston where we have a splendid morning.  jb
Hi everyone. I missed yesterday´s class but I´m glad it´s still there to play on demand :)
mornin' all .... from beautiful upstate New York! (Fingerlakes Region)
Good Morning everyone!
@somaira u from PAKISTAN?
@sumaira its 2102 hours
hye all and good morning !
Hello!
For how long time these lectures are available for listening here?
Good morning from Scottsdale
Good Morning from Frosty San Jose, CA.
 It's 34°F now with a High of 65°F.
Good Morning from GA
hi can u tell me wats the time of class in PAkistan
nonickname_#3
SalemtheCat
HangLai
emesdoublee
emesdoublee
emesdoublee
emesdoublee
