Page 1 / 6   >   >>
anonyme-x22
Rookie
Please Read
anonyme-x22   5/18/2016 8:21:14 AM
Hi,
Forget all about this guy says, it obiously haven't any good ears or technical knowledge.
Vinyl does sound different of cd of course, not better, different.
Vinyl is warmer due to a lot of default, which are pleasure to our ears. (Except clicks )
The only thing where the cd is superior is in the dynamic range which is almost about 60db from all studio records because of the common noisefloor of a normal room (about 30db). So 60+30=90db which is the very early first stage of ear damage.
If you want true uncut signal only the analog support can do it because of sounds overtones whose can be as high as 96khz (today numeric adc is so limited that 192khz is the maximun so higher bandwidth measurment need specific tools)
Rgds,
jjmccormick
re: Vinyl vs. CD myths refuse to die
jjmccormick   11/29/2014 2:49:08 AM
To make matters worse, howstuffworks.com removed the comment section for all their articles. I understand why. Little of the stuff on their web site is not garbage. If you click on the author's name for any particular item, you will see a list of contributors. It is a list of journalism, english, communications, psychology grads and "freelance writers." These are very interesting credentials for people who presume to instruct us on how things work.
It also surprises me that since nearly all recordings since the 80s have been digital and all these "warm" vinyl recordings are actually cut from those digital recordings, that someone hasn't figured out they could put a "vinyl" setting in the equalization of music devices that would introduce various types of distortion, channel interference and even the slight time shifting that results when a vinyl disk is played on single point pivot tonearm system.
I started buying vinyl when I was a kid in the 70s because the only other choice was 8-track. It was good enough for rock because the loudness wars were already well under way (to which Audacity waveforms from my mid-70s lps will attest), but when I bought my first classical record, the romance was over. Thankfully, I only had a couple of years to wait for my first CD. This vinyl thing people have is... well, another poster said it, and it bears repeating: "There's a sucker born every minute."
robotczar
robotczar   2/27/2014 11:27:57 AM
These responses show that the myths are entrenched and continue. The Redbook CD format was chosen because it is sufficient for playback encompassing the limits of human hearing. Higher bit and/or sampling rates\ formats are either marketing tools (that have failed) or provide some headroom for mixdowns that stay near the max specs of the CD format. Nobody has been able to show they can hear differences between the formats under scientifically controlled conditions (which is not true for compressed formats like MP3). The fact that some people claim to hear improvements on discs with both Redbook CD and higher rate formats can be due to the record company tweaking one to sound "better".  On the topic of sounding better, LPs add noise (warmth and spatial effects) to a recording that are not present in the original recording due to limitations of the medium, which is preferred by some listeners. A CD is capable of providing such warm sound (which can be tested by recording an LP to CD and comparing).  So, listeners can choose either medium based on what they like, but only one has higher fidelity. It is a valid point that the recording and mastering process affects the quality of the sound and can sound different (and bad) on either playback medium.  But, LPs measures worse than CD in every way and also sort of self-erases itself (and acting like a microphone, picks up the played back sound resulting in increased distortion (which is already higher than CD). LPs have a very kludged way of implementing 2-ch stereo that is subject to lots of spacial distortion (that I think some people like). Bottom line is people have preferences, but it is a different matter to claim your preference is superior, especially in terms of fidelity.
THest
THest   5/7/2013 9:04:29 PM
In 1982 I bought a Luxman LV-103U hybrid tube amplifier.... well, it was in 1992 ;-), sorry!
THest
THest   5/7/2013 9:02:37 PM
Hi. Googling on the subject, I came to this site. Found it is an interesting site in the process ;-) Forgive me, if my English seems a 'bit off'. I'm from Denmark. On subject: 'Fact' are _not_ irrelevant. Fact is, that what the artists produced at the recording is most precisely recorded on vinyl as opposed to CD. No debating that. It's logic and physics. I read an article, that most young people today have never even _heard_ analog music, not to mention on anything else than, say, an IPod. Not a real stereo with 'real' load speakers. It's the generation of low quality MP3, which is why, I suspect, the vinyl has had a renaissance of sorts. We old dudes (44 ;-) have grown tired of low quality. An anecdote from a real experience: In 1982 I bought a Luxman LV-103U hybrid tube amplifier and it's CD player match, also with tubes. IT WAS expensive and the CD player was top of the line(s) at that time. I love classical music (not only ;-) and I thought this would out match my Thorens 318 turn table any day. It did NOT. The CD player had a very specific problem with violins. The problem is a bit difficult to explain, but it was extremely clear and impossible to not notice: Whenever violin-players 'started setting the bow to the string' (make any sense ?), the result coming from the speakers was the sound of an ice skater braking. Remember having seen/heard on TV, a figure-skater stopping from 'high-speed' and stopping 'side-ways'? And I could repeat the effect with virtually any CD I had on the shelve. As a result, and very dissapointed, I went back to the store (KT Radio in Odense, Denmark) with all my equipment. We tried at least four different high end CD players in different configureations, and they all showed the exact same problems with different CD's and recordings. Props though to KT Radio: They actually gave me a new OM 30 Ortofon needle for my Thorens, for my trouble ;-) Customer satisfaction pure!! :-)
ric03
ric03   3/7/2013 2:10:06 PM
The "facts" are irrelevant: you cannot prove something that is subjective. Digital sounds slightly clearer, has the benefit you can listen to a whole album without getting up and is easier to rip to your computer; [to me] Vinyl sounds warmer and resonates more (feels more like listening to live music). Either way, you get what you pay for. If you spend £500+ on a digital or analog system you're going to be in for some great experiences. Not inclined more either way (they are both fantastic formats), just think we're lucky to have the choice.
Bill123098
Bill123098   1/11/2013 2:58:36 AM
Oh, I'm in no way 'bigging up' vinyl. Rather stating that CD isn't all that great either, and we should be talking about real digital audio-tech.
Bill123098
Bill123098   1/11/2013 2:33:33 AM
Can I ask the writer? Is there any audible difference between 16-bit and 24-bit? 44k and 96k-- to me there most woppingly certainly is! CD is limited to the latter; let us also remember CD is a rather old format. As for the viewer speaking of "The Nightfly": A terrific album, I suggest you listen to it in 24/96, it will blow you away. Oh, and pick up "Morph the Cat" while you're at it.
sidewayz
sidewayz   12/27/2012 3:33:33 PM
I grew up with CDs and listened to them extensively in my youth; yet I tend to find more richness in the sound delivered by records. To this day, I have not heard recorded percussion notes that sound anywhere near as sharp as they do on a 45 long play. There's a reason for this; Turntables do something that DAC's can't. They reproduce exactly what's pressed into the medium. CDs may have a greater resolution, but the sampled audio generally creates a notchy waveform. Therefore, most DAC's within a given CD player will apply a smoothing curve between sampled points. This curve is an ESTIMATION that's performed on the fly by hardware. This fact alone isn't something that's not particularly suited to discerning tastes. Yes, 44.1 kHz of 16 bit sample may seem like a very large number, but the smoothing + errors are clearly discernible in the overall recording. I have to say that I'm very happy that CD players come with a DAC that's capable of smoothing. Back in the early 80's, only the very top models offered this function. Smoothing certainly beats a notchy waveform. If low SNR and maximum dynamic range are all that's important, stick with the CD. If you prefer richness and honesty, give records another try. Using a Pro-Ject Debut carbon with an Ortofon OM10 stylus, I find that the sound of records (of good quality and of a decent, cleanly condition) is crisper than anything digital. The audio is also more elastic and natural. It emulates guitars and other stringed instruments perfectly - especially the bass guitar. If I close my eyes, I almost feel like I'm at the concert. Listening to digital music afterwards is like listening to muffled music. Sounds a lot smoother, but not nearly as sharp.
kjdsfkjdshfkdshfvc
kjdsfkjdshfkdshfvc   12/16/2012 12:19:48 AM
A quick comment: The 44.1khz sampling rate was chosen for MONEY reasons not for audio quality and it's way too low of a sampling rate for anyone who cares about audio quality.
Page 1 / 6   >   >>
