mevlut
re: Techniques for accurate ECG signal processing
mevlut   5/26/2014 3:07:52 PM
ECG arrhythmia detection using an artificial neural network matlab code of signals do you need help?
urgent
urgent   5/12/2013 7:41:00 AM
hi sir , actually the instrumentation amplifier i m using is AD620 and the with value of gain resistor Rg= 8.2kohm , but when i saw the output of the instrumentation amplifier on the CRO, then i havent getting any kind of signal , and what should be the gain of overall ckt ?
green_is_now
green_is_now   4/29/2013 3:29:59 PM
If volume of a MPU can allow lower cost solution then a dedicated product then it may make sense. But I want two more firmware guys on the team. Meaning volume and extra development cost risk would need to be considered when deciding dedicated over MCU. Caveat have not used PSOC yet. Perhaps all the hype from Cypress is correct and it is very easy to use with very little programming. Any PSOC users out there? Chim in please we need real folks with real experience to explain why PSOC is so easy to use.
Tabdata
Tabdata   3/30/2013 1:18:45 PM
Thanks for the nice article
you_sun
you_sun   4/20/2011 4:10:14 PM
is there a reference design or a demo system?
Devad
Devad   3/2/2011 6:35:11 PM
A PDF would be nice.
krisi   2/23/2011 3:15:22 PM
thank you Umanath...
umanath.kamath
umanath.kamath   2/23/2011 10:10:21 AM
Hi Kris, The gain is adjustable and can be from 1,2,4,8,16,24,32,48,50 which are custom available for the Programmable Gain Amplifier. For the instrumentation amplifier, either the two opamp topology using 2 PGA's can be implemented (Differential Amplifier Topology with one PGA having positive gain and other Negative gain) or a three opamp topology can be used. Hi All, The article will be shortly available as PDF on our website at the following link: http://www.cypress.com/?id=2010&cache=0 This article mainly highlights the capabilities of an off the shelf programmable mixed signal controller and illustrates one such medical application using a range of available functionalities that can be easily implemented. Regards Umanath
krisi   2/17/2011 7:33:13 PM
Great paper...is gain adjustable? what is the range? dr Kris
agk
agk   2/17/2011 8:37:08 AM
PSoC can reduce the size and weight of the product. A good communication interface it provides with other systems.Cost saving and low power. Tha applications can be designed with a friendly user inteface.
