docdivakar
re: Missing sensor hits global automakers, say IHS
docdivakar   4/11/2011 8:05:15 PM
@DrQuine: airflow sensors are employed in multiple places within a vehicle. In addition to the example mentioned above, you can find a combined airflow+thermal sensor (like the ones manufactured by Cambridge AccuSense) used in many vehicles where you can set the cabin temperature. I have used AccuSense airflow/temp sensors in thermal characterization wind tunnels for semi packages. You can get airflow sensors of many makes and many countries today. @peter.clarke: you are right, it is the question of getting the second and third source vendors to come on-line quickly assuming that there were enough qualified ones in the approved vendor list. But what I don't yet see is the mitigation of shortages in the sensor because of slower car sales which may be due to other reasons too (not to mention the $4.50 per gallon of gas price in the N. CA bay area!). Dr. MP Divakar
KB3001
KB3001   4/6/2011 2:06:59 PM
The system will indeed find a new stability point. Trust free market economics...
Peter Clarke   4/4/2011 12:45:35 PM
It is not that this sensor CAN only be made in Japan but that the supply chain gravitated to a position where it WAS only made in Japan. In fact demand will fall anyway. I have read that car sales in Japan in March fell 37 percent year-on-year, the biggest ever drop recorded. Because cars are not moving off care sales lots there will be less demand for car manufacture, which mitigate some expected supply chain shortages.
jaybus0
jaybus0   4/2/2011 12:42:43 PM
Indeed. In the computer disaster backup and recovery world, we would call this a "single point of failure". The solution is redundancy, not having spare parts on hand. For example, load-balancing two ethernet controllers connected to two different ISPs ensures that a catastrophic failure of one can never result in a complete loss of connectivity. On the other hand, having a spare ethernet controller on hand and the knowledge that other ISPs exist guarantees some down time. Second sourcing in JIT supply chains likewise guarantees down time. The solution is to "load balance" both sources in normal production. A loss of one source can then slow production, but never stop it. This is not easily accomplished, of course, due to intellectual property issues. The increased competition works in favor of the consumer, but not in favor of the supplier owning the IP.
t.alex
t.alex   4/2/2011 8:50:47 AM
I understand airflow sensor is for engine control. I false reading can lead to engine malfunctioning or even affect fuel efficiency. Seems only in Japan can this be produced?
SimulinkJocky
SimulinkJocky   4/1/2011 8:45:15 PM
Unless an alternate source can be found, or production can be restarted, this could be the start of another recession. With auto production shutting down because of this, lots of workers will be put out of work, at least temporarily. This doesn't sound good at all.
GREATTerry
GREATTerry   3/31/2011 1:52:48 PM
This impacts the whole world quite much. From a optimistic standpoint, this may help to slow down the pollution a bit by reducing the growth of car owners.
Sheetal.Pandey
Sheetal.Pandey   3/31/2011 10:49:21 AM
These natural calamities take the developments back in time. Japan was coming up as one th emost advanced countries, but I guess they will bounce back. How much of the production happening in this facility?
DrQuine
DrQuine   3/30/2011 2:43:46 PM
What role do air flow sensors play in consumer cars? In the event that I'm not the only uninformed reader, I did some quick research in Wikipedia (again) and learned: "A mass air flow sensor is used to find out the mass of air entering a fuel-injected internal combustion engine. The air mass information is necessary for the engine control unit (ECU) to balance and deliver the correct fuel mass to the engine. Air changes its density as it expands and contracts with temperature and pressure. In automotive applications, air density varies with the ambient temperature, altitude and use of forced induction and this is an ideal application for a mass sensor."
lifewingmate
lifewingmate   3/30/2011 6:01:09 AM
It seems that these airflow sensors are particular to Japanese manufacturing. I remember reading in other EETimes articles about certain raw materials that are only available from Japan. I with agk that automobile manufacturers need to find another way to compensate. The closing of production lines for this one part can mean reduced jobs and many other consequences.
In conjunction with unveiling of EE Times’ Silicon 60 list, journalist & Silicon 60 researcher Peter Clarke hosts a conversation on startups in the electronics industry. One of Silicon Valley's great contributions to the world has been the demonstration of how the application of entrepreneurship and venture capital to electronics and semiconductor hardware can create wealth with developments in semiconductors, displays, design automation, MEMS and across the breadth of hardware developments. But in recent years concerns have been raised that traditional venture capital has turned its back on hardware-related startups in favor of software and Internet applications and services. Panelists from incubators join Peter Clarke in debate.
10:29
