rohvemula
re: Driving Impressions: Chevy Volt
rohvemula   8/25/2011 9:33:37 PM
Bob: I am curious to know taht do you own any EV? If so whcih one you own or driven any? In USA either EV or some other vehicle is required for personal transportation. The present Chevy Volt should/will cahnge how we use the car. Now it is expensive. The technology of all kind of batteries are not optimized. Need to do alot of researh. Do you agree? If there is not demand there is not necessity to make and invent.
rohvemula
rohvemula   8/25/2011 9:27:02 PM
Mr. Manning: One can not compare to MINI Cooper or any other autos to Chevay Volt. This is entirely different kind of car, no car exists as of now to compare. Battery is guranteed for 100K or eight years which ever comes first. But GM did not recomends or suggests to replace the battery. If I am wrong please correct me. It is said that USA have enough capacity to support even if all autos are converted to EV. Or New industry will be creasted. And the OIL will be used for other purpose rather than just use it in IC autos. Tks Roh
rohvemula
rohvemula   8/25/2011 5:05:39 PM
Mr. Harrison: You are correct. I won this car Chevy Volt. I bought this car in May 2011. In one word it technically advanced auto.Thanks to GM to bring this car to market. This is not a cheap car. One can by Benz for this price. Now they bring the price down to affordable level by improving the battery range to minimum of 100 miles from 40 miles. Hope to see great future of this kind of technology and no one will venture to kill it. Unitl unless the cured oil come down to $10 per barrel level.
rohvemula
rohvemula   8/25/2011 3:08:54 PM
Bob: I own Chevy Volt. I took delivery of this vehicle on May 19th, 2011. Also I got installed 220 Volts charges under DOE program. To charge fully deplated battery it takes about 12 to 13 KW. Now you can compute how much it costs to drive about 35 to 40 miles per charge. Chevy is one of the technologically advanced automoble in recent history of US Auto. It will take time to make this kind to maix perfection. Many people commented about the price. It is expensive, no doubt about it. If one can offered it and need it should buy. Everyone remembers that when Personal computer was introduced by IBM the cost was several thousands per PC. Now it is hardly couple of hundreds. When many cars of this kind produced and there is competetion to sell the price will come down. Send me your commets to my email vemula884@aol.com
rohvemula
rohvemula   8/25/2011 12:40:41 AM
Chevy Volt is completely different vehicle, can not be compared with any others. It is functional. Nissan Leaf may be advanced and pure electric. But after the battery is depleted in highway what do you do?
rohvemula
rohvemula   8/25/2011 12:38:47 AM
I own Chevy Volt. There is not change in performance. It is fund to drive. This is technologically advance vehcile in many folds
selinz
selinz   8/24/2011 6:01:18 PM
once the MiniSD is reported on Fueleconomy.gov, you can make a reasonable comparison. European papers also reported the Volkswagon TDI's getting in the high 50's but when it showed up, an apples to apples comparison resulted in showed 31/43 city and highway. This is nearly the same as the 35/40 reported for the VOLT in GAS only mode. The value is 95/93 in electric mode.
DJH832
DJH832   8/17/2011 7:22:59 PM
I am curious about the performance after the battery has been depleted & the small gas engine now has to power both the car & recharge the battery -- it must be very underpowered & sluggish under those conditions. Don H.
Bob Lacovara
Bob Lacovara   8/8/2011 3:17:25 PM
cdhmanning, it may not be any better at all. In fact, having a single motive source in a vehicle strikes me as almost always a better idea, overall, than having both an electric and an IC motor with the attendant complexity and maintenance. At 60 mpg, the Mini Cooper SD sounds like it could give any hybrid of similar size a run for its money. And you are correct: a cost often overlooked is the cost over time of the battery. But here's a difficulty: when you leave a relatively simple analysis of "what goes in the car, and what does it cost per mile" and begin to ask a more sophisticated "what is the overall cost of ownership?" then the analysis must be done with great care, so that apples are compared to apples, and skunks are compared to skunks... ;-) As to electric power distribution, your point is taken, but since we don't have the problem yet, and it's not really on the horizon yet, it's hard to worry about. Stations that change out batteries; stations that remove spent electrolyte and replace it with new electrolyte: all of these possible future infrastructures will come at a cost borne by the consumer. Here's something that's certain: if you build a better mousetrap, the world will beat a path to your door. We aren't seeing any paths being beaten for hybrids or EVs because they are not sufficiently better than Corollas, Mini Coopers, etc. for enough people in diverse needs.
Bob Lacovara
Bob Lacovara   8/8/2011 3:09:23 PM
Dr. Quine, I'm not sure what you mean by "modified" when you mention the mpg in electric mode. Obviously, if you are running only electric, there is a direct cost to you to recharge the battery. Similarly, there is a cost of fuel if you are running a longer distance. Both of these can be observed. What's to be modified? Comparing these numbers to any of various alternatives is useful, but modifying the numbers to reflect the inefficiency of IC engines in short trips (which is certainly true) would merely complicate the comparisons, no?
