Page 1 / 8   >   >>
subman
re: FBI raids Solyndra headquarters
subman   9/13/2011 10:48:02 PM
Well, let's see, perhaps that's not a very tough analysis...let me take a stab: Positives: - Catchy name based on unique tube design. - Good political connections to help get funding. Negatives: - product cost is higher than competitors due to goofy tube design - product efficiency inherently low due to goofy tube design - manufacturing in one of the highest cost and highest regulation regions in the world. Pretty rare that any major companies are building plants in CA these days, and there are presumably good reasons for that. - manufacturing a product who's sales are driven only by govt regulation as opposed to value to customers (Germany, not exactly known for its bright sun, is ~50% of the market) creates large demand risks. Lower cost chinese competition exposed a bad business plan. It doesn't take a rocket scientist to see how bad the plan was. It does take a politician to throw half a billion taxpayer dollars at it.
Water Man
Water Man   9/13/2011 10:18:18 PM
Simmer down seaman!
Paul.Pacini
Paul.Pacini   9/13/2011 6:46:22 PM
LMFAO! That's classic! I hope you don't mind if I copy-n-paste email this out to some business/music friends. Thank you for the laugh!
Paul.Pacini
Paul.Pacini   9/13/2011 6:41:02 PM
Very true. A place I worked for came under a raid and they dragged our CFO out and put him in jail for a few years. He was charged with some sort of fraud from a previous employer. It freaked everyone out, but then ended quietly and we all returned to normal work in just a few days – with an open req. for a new CFO. . .
asimecs
asimecs   9/12/2011 10:44:27 PM
We should analyze why Solyndra failed & learn from it. This is something that impact Fremont, Silicon Valley & California as a whole. We are at risk to fall behind China in solar industry. Let's unite & help America.
chipmonk0
chipmonk0   9/12/2011 7:45:56 PM
bigchin : can you pl. provide the URL where you found that
subman
subman   9/12/2011 6:50:18 PM
1000 direct employees, but in order to comply with terms of Obama's green loan guarantees, they needed to comply with the Davis-Bacon Act. This requires highest-cost union labor for all construction. That beautiful building in Fremont wasn't cheap, and I'm sure a high percentage of costs went to construction labor.
subman
subman   9/12/2011 6:43:03 PM
How do you leave the politics out of this? This was a highly political company funded by the government to support a highly political initiative. If it weren't for politics, unlikely Solyndra would be an issue.
KB3001
KB3001   9/12/2011 6:19:17 PM
Correct! Bad for taxpayers either way... PR-wise, it's also a disastrous news for the technology sector.
ck_02
ck_02   9/12/2011 6:13:07 PM
Cite your source please
Page 1 / 8   >   >>
michigan0
SteveHarris0
SteveHarris0
SteveHarris0
VicVat
Les_Slater
SSDWEM
witeken
9/25/2016
4:48:30 PM
michigan0 Sang Kim First, 28nm bulk is in volume manufacturing for several years by the major semiconductor companies but not 28nm FDSOI today yet. Why not? Simply because unlike 28nm bulk the LDD(Lightly Doped Drain) to minimize hot carrier generation can't be implemented in 28nm FDSOI. Furthermore, hot carrier reliability becomes worse with scaling, That is the major reason why 28nm FDSOI is not manufacturable today and will not be. Second, how can you suppress the leakage currents from such ultra short 7nm due to the short channel effects? How thin SOI thickness is required to prevent punch-through of un-dopped 7nm FDSOI? Possibly less than 4nm. Depositing such an ultra thin film less then 4nm filum uniformly and reliably over 12" wafers at the manufacturing line is extremely difficult or not even manufacturable. If not manufacturable, the 7nm FDSOI debate is over!Third, what happens when hot carriers are generated near the drain at normal operation of 7nm FDSOI? Electrons go to the positively biased drain with no harm but where the holes to go? The holes can't go to the substrate because of the thin BOX layer. Some holes may become trapped at the BOX layer causing Vt shift. However, the vast majority of holes drift through the the un-dopped SOI channel toward the N+Source,...
