Neo10
re: ARM reveals little dog A7 processor
Neo10   10/25/2011 5:50:04 AM
The task/app switching should happen on the fly, perhaps run by a secure kernel layer with high priority.
Kinnar
Kinnar   10/23/2011 2:57:19 PM
Yes it is quite true why a designer will host two different chips and going on switching applications between both of them, instead multiple cores will be better option, the power concern can be handled by turning on and off the cores dynamically.
t.alex
t.alex   10/23/2011 1:59:11 PM
How can the OS decide which core?
timemerchant
timemerchant   10/23/2011 5:57:01 AM
Tools vendors will have their hands full with all the derivative cores. MIPS did this a while back with incompatible cores. As it is, every six months there is another ARM core, with their CMIS standards etc. If one A15 and one A7 core is run in the above diagram, the cache split will be interesting, and what about tracing this lot? How does the core decide what load to run? Surely the developer has to specify this. The comparisons of different cores at 45 and 28nm is misleading. Will be interesting to see how this takes off against NVidia, iMX6000 and other multi-core vendors with identical cores.
PoorMan LP
PoorMan LP   10/23/2011 3:22:24 AM
Not saying how important of the numbers of multi-core technology, ARM still has long way to go to deploy superior multi-core solution, like efficiency of ACP to improve I/O performance and Virtualization ...etc. Compare to ARM, MIPs IP price is far cheaper but eCosystem and power efficiency are also weak. I've seem lots of me-too product with ARM solution in the market for specific regions, especially, China, Taiwan and Indian deploy similar Network and Media SoC in the market. That says, ARM is the winner of IP biz and leave the product competition to the chip design house.
collin0
collin0   10/21/2011 4:39:31 PM
For power efficiency, ARM do the best. It is its key competition. In China, more and more companies start to use ARM architecture IC with embedded Linux to develop products. The ARM core IC has the most large share market in China. It is also my first choice to make the new project.
GREATTerry
GREATTerry   10/21/2011 12:31:15 AM
It is an interesting idea. Hope this can really help to solve the battery run time issue.
Paul A. Clayton
Paul A. Clayton   10/20/2011 11:32:11 PM
ARM provides a mechanism using the existing OS interface for DVFS (low-power modes) to enable switching between core types (with the option of an implementer exposing the additional cores to the OS).
Duane Benson   10/20/2011 4:00:46 PM
Add in a graphics co-processor and you have little, big, bigger. It's an interesting approach and does make sense. With the graphics co-processor architecture, high-power functions are offloaded from the main processor. With this approach, low-power functions are off loaded from the main processor.
Peter Clarke   10/20/2011 8:58:51 AM
My understanding is that for identical cores On a chip ARM does offer a slight discount...this would drive down the royalty rate per core if ARM was not able to drive up the base rate! ARM can try and do that by arguing that newer cores have increased functionality, performance. licensees can resist by saying that too higher royalty rate will make them look elsewhere!
KATG
Rcurl
traneus
traneus
Tony Casey
David_Ashton_EC
Tony Casey
6/30/2016
11:36:46 PM
