markhahn0
re: Four reasons why MIPS new cores may make it relevant again
markhahn0   6/16/2012 3:35:48 AM
regarding the (mistaken) claim that ARM has already won: observe that pretty much all wifi routers are MIPS, not to mention a lot of NAS and other embedded networking. those are a lot less salient as the ARM in your phone, but at least as significant in ecosystem.
junko.yoshida   5/15/2012 2:33:11 PM
HI, Bill-MIPS. Thanks for chiming in. It's easy for anyone outside MIPS to second guess what MIPS engineers are doing. What we need is more voice from people like you!
prabhakar_deosthali
prabhakar_deosthali   5/15/2012 5:30:15 AM
Are MIPS new release processors code compatible to ARMs? Like those AMD and Intel?. In that case at least MIPS has a chance to be the second source to ARM
TechRoadRash
TechRoadRash   5/15/2012 5:23:29 AM
As a member of the MIPS engineering team, I can tell you that I am working on some of the most exciting and challenging work of my career. These are not minor updates to old products, but completely new architectures built upon MIPS’ deep expertise in processor architecture. Some of the engineers I work with daily are from the original Silicon Graphics MIPS team, and others are from well-known processor companies. The work here is intense, exciting and continually intellectually challenging. Sitting next to me is a compiler team working on sophisticated projects, down the hall is a CAD team working on advanced nodes and on the other side of me are engineers working on OoOE pipelines. Our software team is doing amazing work, having recently completed the work necessary to get our NDK into the official Android source tree. In this highly competitive market, we have agility, expertise, and a fast and exciting work environment.
anon3860072
anon3860072   5/15/2012 1:55:47 AM
In this regard, the release of hardened A15 core on TSMC 28nm process is definitely an advantage at the moment.
anon3860072
anon3860072   5/15/2012 1:53:32 AM
Are you sure that no Android app uses compiled code? You should talk to Ingenic and its customers or to Philips China. I bet that if you try any of these 7" tablets in US or in Europe, you are going to see something broken. In the ideal world, there is no compiled code, in the real world, optimization will inevitably lead to the necessity of compiled codes.
KC9
KC9   5/14/2012 6:03:18 PM
We can also see the fact ARM vs. MIPS from the silicon process point of view. ARM is now moving forward to the 22nm process. MIPS is far behind ARM in terms of the silicon process but MIPS still has some advantage for cost and energy consumption if they start using a 32nm process.
tb1
tb1   5/14/2012 4:02:32 PM
I was thinking of Android, not iPhone. Android apps are not compiled code--you can even run them on an Android simulator running on your PC (and the simulator isn't simulating Arm assembly code). In fact, Motorola is coming out with an Android phone that uses an Intel Atom processor later this year. Certainly Android itself has to be compiled to run on the processor. But from a customer point of view, any processor will run the apps, so they will tend to prefer the phone that runs the fastest with the longest battery life.
jeremybirch
jeremybirch   5/14/2012 1:05:25 PM
"you don't run compiled code" - sorry? On iPhone you are generally running compiled objectiveC. I know some platforms are aimed at running java/javascript - but underlying both of those is compiled code too (eg in the browser). Ok - with Android you might hope the heavy lifting s done by Google - but you cannot get away from a certain amount of compiled code and hence instruction set dependency. And if the main objective is high performance with low power consumption you are not going to optimise that whilst having multiple layers of interpreter and virtualization, because you will be running more code than necessary.
moronda
moronda   5/13/2012 7:43:03 PM
ARM is stable and things work. Porting to a different processor has huge risk. Anyone that tells me that switching processors is a breeze I do not believe. Anyway, I'm sure the moral there is completely in the toilet. What are the MIPS employees doing? Brushing up the resume to go to ARM, Intel, Freescale, Cavium, Broadcom, etc... If they are smart.
