Thomas_nomad
Rookie
Novice
Thomas_nomad   10/13/2016 2:15:27 PM
I am an industrial designer and we have a challenge to design a sound system as a key component in a suite of products for mobile/smartphones. Rich sound from micro speakers is exactly what we seek, any takers out there interested in collaborating? Send me a note. Thomas@analog-lab.com
hsprr
Micro Speakers
hsprr   8/6/2013 2:12:16 AM
Do we have any mobile phone  using micro speakers which use piezoelectric actuating principle?
Do they use PZT (or any other piezo electric material) as membrane?
I_B_GREEN
re: Achieving loud, rich sound from micro speakers
I_B_GREEN   8/3/2012 11:13:04 PM
How about using some of that air pumping functionality to cool the coil? Add a sub chamber and and a mechanical diode (one way valve for the air) and project it along the coil or better inside it. badabing badabong. Now only do this at the exteme travel points and add damping and only pump cooling air when at max power when you need it.
bcarso
bcarso   8/1/2012 10:02:10 AM
Yes, and not only with temperature but with aging. Ideally, positional determination should be independent.
Tony Casey
Tony Casey   7/30/2012 11:06:59 AM
That's not something you can rely on either. For example, suspension compliance will change significantly with temperature, changing both the resonant frequency and impedance peak. Moving mass, on the other hand, should remain constant. :-)
calebcrome
calebcrome   7/30/2012 6:06:31 AM
Good point. But the *rise* in impedance should be linear with temperature. so, if you take a 25C measurement across the spectrum, you should get a nice linear increase across the full spectrum as temperature increases.
agk
agk   7/27/2012 12:37:23 PM
Author has briefed an important topic and triggered my thoughts. Always there is research going on improving the quality of the sound produce by the loud speakers. This is because the loud speaker efficiency is around 5% maximum. When it comes to fidelity again a quite a lot of limitations. This is because the speaker has to reproduce about more than a 1000 different types musical instruments sounds from a big drum to a smallest string instrument.So naturally it is difficult to design a single transducer to reproduce these sounds.And micro loudspeakers really tough to satisfy.Researchers can think of any other new type of transducer.
tbia
tbia   7/26/2012 7:21:27 PM
While what the author is stating is true it is much more important to provide a means of acoustic control over the diaphragm. The low frequencies need not be limited by back EMF nor the highs by inductance if a means to provide constant pressure behind the driver is provided. Typically the driver will have a more shallow roll off and not experience as much breakup under these conditions. Pat.7207413 B2 and others pending to allow for dynamic volume modification of the enclosed volume behind the driver. Impedance variations are also not as aggressive and critically damped resonance peaks enhance bass response. These conditions are established pre-electronics allowing for less aggressive DSP requirements to fix the speaker.
AJW in OR
AJW in OR   7/26/2012 4:58:23 PM
Does this part have any value for piezo speakers?
bcarso
bcarso   7/26/2012 4:20:28 PM
OK, so as far as I can tell the cone positional information is not exactly acquired in real time (which would be very difficult) but rather developed as a model which resides in the DSP. Brad
