Design Con 2015
chrisshore
Blogger
re: Slideshow: A brief history of memory
chrisshore   12/5/2012 10:16:45 AM
Not to mention the absolutely wonderful "rope memory" used in the Apollo Guidance Computer systems. A form of almost physically indestructible ROM in which the memory contents were encoded (literally "hard-wired") by weaving (by hand) the sensor wires in and out of a string of ferrite cores. Changing the contents of the memory meant unravelling the string and re-weaving the wires. http://en.wikipedia.org/wiki/Core_rope_memory
SylvieBarak
Rookie
SylvieBarak   12/5/2012 6:17:53 AM
Lest we forget.... ;)
steveDS
Rookie
steveDS   12/4/2012 3:34:15 PM
Pictures here: http://vipclubmn.org/Memory.html
steveDS
Rookie
steveDS   12/4/2012 3:06:09 PM
Sperry Univac had a drum memory that was ~6 feet in diameter and ~18 inchs wide. Had a head per track so no moving parts except the drum. Because of the large diameter it did not have to rotate very fast to get a high speed at the R/W head
Kristin Lewotsky
Blogger
Kristin Lewotsky   12/3/2012 8:22:05 PM
Apparently, I was having an out-of-body experience when I calculated 750 kHz--the actual figure is around 200 Hz. Good catch.
andyzg
Rookie
andyzg   12/1/2012 9:52:59 PM
hmmm. in the mid 80ies there was a type of Intel memory that acted as SRAM, but upon power failure was able to write the whole array into EEPROM or Flash cells, in parallel, before power was gone. don't remember the name though...
Jack.L
CEO
Jack.L   12/1/2012 8:58:20 PM
Cool article by the way. There were a few technologies I had never heard of.
Jack.L
CEO
Jack.L   12/1/2012 8:55:42 PM
I actually "touched" magnetic core memory in the late 80's in a professional capacity. It was used in some Allan Bradley PLCs that were in an industrial plant I worked in as a student engineer. Hard to believe it was still in use as little as 25 years ago in functioning equipment.
Kevin Neilson
Manager
Kevin Neilson   12/1/2012 2:20:54 AM
This was really interesting. Good work. I'm dubious of one stat, though: it doesn't seem possible that the magnetic drum rotated at 750,000 rotations per second. In fact, that most definitely can't be true. Sometimes in my HDL code when I use a delay line or Johnson ring I call it a mercury line. It's the same concept. The springs in old reverb units are similar--they're basically FIFOs.
DResnick
Rookie
DResnick   11/30/2012 2:26:53 PM
In addition to the magnetic core implementation shown, there were other variations according to the number of wires through each core. There were 2, 3, 4, and 5 wire varieties. In the 2-wire type, all the bits in a row are accessed at the same time. The Control Data Star-100 used this type of memory.
DrQuine
drmrs
R_Colin_Johnson
R_Colin_Johnson
R_Colin_Johnson
EE Life
Max Maxfield
Is Your System Cyber-Secure?
Max Maxfield
22 comments
Until recently, I was under the impression that my computer system in general -- and my precious data in particular -- was reasonably secure against the forces of evil, but then my eyes ...
Rich Quinnell
Bloopers Book Helps Improve GUI Development
Rich Quinnell
2 comments
Courtesy of fellow editor "Max" Maxfield (aka Max the Magnificent), I recently acquired a copy of GUI Bloopers 2.0 by Jeff Johnson of UI Wizards. I found it an interesting read chock full ...
Martin Rowe
Make This Engineering Museum a Reality
Martin Rowe
Post a comment
Vincent Valentine is a man on a mission. He wants to make the first house to ever have a telephone into a telephone museum. Without help, it may not happen.
Rich Quinnell
Rich Quinnell
16 comments
10:29
