johnwood
re: Servers cool it with liquid refrigerant
johnwood   4/1/2013 6:24:04 AM
I had very similar issues with my refrigerator but no more it happened again and again because I got reliable commercial refrigeration service, John Wood http://www.bergenrefrigeration.com/
DrQuine
DrQuine   1/8/2013 3:32:25 AM
There are also the hobbyists who cool their motherboards with liquid nitrogen so they can clock them very fast. I think that a major issue with all liquid cooled systems is that the coolant requires more maintenance than the underlying computer. It also represents a common point of failure that can take everything else down. Air cooling may be crude - but it is relatively robust.
green_is_now
green_is_now   1/2/2013 8:03:41 PM
Use the phase change delta pressure to provide the power to drive the liquid pump with a small turbo-turbine coupled to liquid pump. Then it would be self contained and need no electrical input.
DResnick
DResnick   12/21/2012 2:34:20 PM
Before Cray Research used Fluorinert, he used Freon in two systems: CDC 6600/6400 and the CDC 7600. And BTW: Could not get a similar cooling system working for what was to be the CDC 8600. That failure is why Cray left Control Data and formed Cray Research.
markhahn0
markhahn0   12/20/2012 10:23:34 PM
what would be really interesting is if someone (Intel) promoted a standard location for a cold plate on a standard 1U. vendors could arrange heatpipes inside the chassis however they liked, and the rack vendor would be responsible for circulating coolant through the plates that mated with the chassis plates... modular, non-proprietary and not requiring a coolant hookup for each server.
CommonSense1
CommonSense1   12/20/2012 5:51:01 PM
Technology triumphs! Let's try this: I have been continually surprised that a liquid-based cooling sysem has not been put in place for servers: much more efficient than cooling with air. (I am also a little disappointed there is not opportunity to edit/delete a post when errors are made.)
CommonSense1
CommonSense1   12/20/2012 5:47:27 PM
Cray addressed a similar problem about 30 years ago by pumping Fluorinert liquid through his supercomputers, then cooling it in a heat exchanger. I have beenc ontinually surprised that a liq
