morissonalex
re: Samsung tops leading-edge chip-making capacity
morissonalex   4/30/2013 5:05:04 PM
I'am sure that is not correct, Samsung cannot lead at all Alex from http://basketballtrainingpro.com/
aaschmidt
aaschmidt   4/8/2013 11:26:15 PM
It is not about the utilization, but about product price. Memory is relatively cheap. I bet utilization is always nearly 100% for memory fabs.
help.fulguy
help.fulguy   4/8/2013 6:30:04 PM
Who the heck cares.
Peter Clarke   4/8/2013 4:44:51 PM
@pradipK Thanks for spotting my spelling error. It has corrected in copy.
the_floating_ gate
the_floating_ gate   4/8/2013 2:31:13 AM
All IC insight had to do is break down Samsung waferstart capacity into logic , NAND and DRAM. Logic is far more capital intensive compared to memory. Rick Hill explained it several times....
daleste
daleste   4/6/2013 6:02:42 PM
Interesting comparison. It would be more interesting to include market share and fab utilization numbers. Intel with greater than 15% semi market share and Samsung with less than 7% shows that having the most capacity does not translate into the most efficient utilization.
pradipk
pradipk   4/6/2013 3:33:32 PM
About 22 percent of global capacity is dedicated to "maure" process nodes at 90nm, 0.13-micron, and 0.18-micron. ...it should be "mature"
Kresearch
Kresearch   4/5/2013 10:36:24 PM
Echo! A mixed comparison. Kind of " Apple" to " Orange" match.
the_floating_ gate
the_floating_ gate   4/5/2013 5:32:43 PM
"The market research firm has ranked manufacturing companies by their installed capacity in four categories Samsung leads followed by Intel, Toshiba/SanDisk, SK Hynix and Micron (see figure 2). The ranking reflects the significance of memory to production volumes, but not necessarily revenues." How many metal layers do Intel CPU have compared to NAND and DRAM? I figure 4X A meaningless comparision
