<<   <   Page 2 / 10   >   >>
re: Intel processor outperforms Nvidia, Qualcomm, Samsung ICs
resistion   6/18/2013 1:04:26 AM
I'm not arguing the relative comparison which shows less power consumption at comparable performance by a processor. I'm arguing this is only a small portion of the battery life consideration. Other considerations like camera use may matter more to users, in the final purchase decision.
resistion   6/18/2013 12:57:25 AM
Sure but we know battery life even under normal conditions exceeds 3 hrs, such as in the laptop battery test, regardless of processor. http://blog.laptopmag.com/best-battery-life-longest-lasting-smart-phones
alche
alche   6/18/2013 12:57:09 AM
Don't see how the argument is valid. If one drives a car with engine at redline, the MPG would not be anywhere near the advertized. Do you use laptop or cell running non-stop math and graphics? On the other hand, the relative performance is meaningful, unless you happen to be on the losing side, that is.
resistion   6/18/2013 12:44:58 AM
It's pretty clear the benchmark is democratically useless. The conditions are not real world.
J---
J---   6/17/2013 11:10:08 PM
If one was to run any of these benchmark repeatedly, the phones battery would die quite quickly. However, we know that is not the case. However, processor power&performance does come into play in terms of total battery life and hence is important.
J---
J---   6/17/2013 11:05:14 PM
Les, my irritation if any is because I believe you are arguing semantics when the details really quite simple and this discussion relates to the article. Arguing semantics is not professional. - Task time is inversely proportional to processing speed. Note that processing speed is one of the factors listed in this article. - Power is directly proportional to average current (again, covered in this article). Task Energy is proportional to (power)/(processing speed). There are no other complexities. As this article stated, processing speed for the Intel chips were on part with the ARM chips, while average (and peak) current draw was significantly less. The ONLY interpretation that can be made is that task energy will be less. Any other conclusion would be to argue semantics.
alche
alche   6/17/2013 10:37:54 PM
By the same measure the ARM camp will be drained in 1.25 hrs, so I guess all those Droids and i- phones must be even more useless ):
resistion   6/17/2013 9:36:42 PM
With the 2500 mAh battery, the Lenovo k900 should be drained at 1 A in 2.5 hrs, which would not sell. Shows how useless this benchmark is, even for Intel ironically.
resistion   6/17/2013 7:00:12 PM
Yes the RF and baseband would be better to be listed explicitly in the benchmark, until it is integrated with the processor.
sriram87
sriram87   6/17/2013 6:35:05 PM
CloverTrail+ is an SOC http://en.wikipedia.org/wiki/System_on_chip Other vendors such as Qualcomm, Nvidia, ARM doesn't build anything more than that. Correct me if I am wrong.
