<<   <   Page 3 / 7   >   >>
Ron Neale   9/29/2013 7:35:20 AM
Resition-If you mean there is some form of interface layer at the Pt electrode that is responsible for the switching and the mecahnism is oxidation-reduction, then I think it is necessary to show the chemical/electro-chemical reaction involved.
ECM or not, for the moment because Ag does not need much encouragement to move in silicon, amorphous or xtal, then for me heat and electromigration/electric field effects suffice. My worry with the Crossbar device is to create the filament, material must be moved from the silver electrode leaving what must be an Ag depleted spongy like contact region of nano filaments. Does that material return to the same place when the polarity is reversed, my view is that the material forms mutiple short filaments around the region from where the silver was originally removed. That is along the lowest resistance paths.
The nice thing about having an interface layer close to the passive electrode that switches and is responsible for the memory effect is the suspect contact at the Ag electrode depleted region once formed does not get modified.  However, I think memory devices that require a forming step different from normal operation do not have much of a future. from my experience with antifuses that used amorphous silicon threshold switching occurred on programming, for the Crossbar device will the first switching event in the virgin a-Si be the same a subsequent ones.
I do have a number of slides that we prepared for a possible article that illustrate what I see as the problem for Crossbar, if you contact me I will send them to you. Also if you want what I think might be an example oxidation and reduction at a single site then perhaps CeRAM might be a better example-more on that later.
Re: CBRAM?
resistion   9/29/2013 6:33:21 AM
Ron, just came across this today, thought back to this discussion. Although it seems the filament growing forward into Si seems different from the deposition "backward" toward silver, it looks like he (founder of Crossbar) is still classifying the Crossbar memory along with the other CBRAMs (as ECM). It is possible the electrochemical reduction is occuring in the silicon instead of a Pt electrode.
http://sites.ieee.org/sfbanano/files/2013/06/Lu_NVMT_2013.pdf
nonvolatile
Re: CeRAM
nonvolatile   8/8/2013 8:58:47 AM
1 saves
Sorry for the typos- key correction:
Mott Insulator: U<delta
Charge transfer: Delta <U
I had it backwards in the last post.
nonvolatile
Re: CeRAM
nonvolatile   8/8/2013 8:55:56 AM
1 saves
There is still a lot of controversy on the bandgap of NiO. But, this is the latest number. This is a photemission band gap which may represent the the lowest level 3d7 to 3d9. Not to be confused with a Band Insulator bandgap. If you look in the literature there are 4 types of insulators: Band Insulators (like SiO2 -wide band gap), Anderson Insulators (Heavily defective materials kills the mobility), Mott insulators (Extended states, like the Bands in a wide band device do not exist, only the coulombic interaction (Hubbard U) forms a gap) and the Charge Transfer type of Mott Insulators ( Same as Mott insulators in principle, but the energy gap is formed from the diference of a lower 2p state from the Oxygen and the upper 3d9 state - this gap is called Delta).
The controversy for NiO was resolved in the  90's when it was discovered by photoemission spectroscopy that it was a Charge Transfer type - this means that Delat is less than U. So for a true Mott insulator U>Delta. It is a fine detail that I mentioned before but did not elaborate. The density of states (DOS) shows a gap for delta around 1.2eV if there are not too many vacancies of oxygen. Thus, the dispersion in Vset and Vreset that is common in these NiO memories is because this Delta is localized and not a Typical bendgap of a band insulator or a semiconductor.
It is very common to confuse the Band theory for independnet electrons (Semiconductors, band insulators) with the Localized "narrow bands" of an insulator with interacting electrons. This has been a very difficult point to explain this device. The correction of the oxidation number at every Ni site is done by fixing the coordination sphere to the required oxidation number that can be manipulated by the applied voltage to set or reset. This is not substitutional elment doping (called hydrogenic states) as it is done in Semiconductors, where the dopant takes a place in the lattice and loses its electron to the conduction band, This is very different, for a TMO usually is not a band insulator. So, the electron is localized and the bound state (forming delta) can be destroyed at Vset via the change in the background electron density increased by the injection from the cathode. It is a dynamic process that changes the NiO from an insulator to a Metal-like material. Undoing this by temperature is not easy -that is why 400 C retention is achieved.
In summary: TMOs are not semiconductors, they switch due to the electron-electron part of the hamiltonian of a solid - that is set to zero for semiconductor because due to pn=ni(2) makes typically a free electron in the conduction band to occur at about every 10,000 atomic site. Thus, the "independent Electron Approximation" works. If your education is only semiconductors, you do not know and cannot appretiate the physics of electron-electron interactions. An example of e-e interaction that you may already know are the superconductors (BCS type) in which a Phonon and 2 electrons interact to form the superconducting state. For hi Tc, the Hubbard Hamiltonian is more in practice to model. In TMO case, the Hubbard Hamiltonian is a classic, and the kinetic energy to Potential energy ratio controls the metal to insulator transition.
My view is that semiconductor only people did not get educated in these fine parts of solid state - that is why to this date few understand the nuances of ferroelectric and now TMO. Brute force filament creation is not the way to go in ReRAM, however for more than 15 years that is all that is done. With this new "Coordination doping" strategy, a TMO is manageable without frying it first with electroforming.
---good tricky question CEO, but we've been there and done that. Careful science is a pre-requisite to real breaktrhoughs. And, data talks - so if we have no electroforming by materials design, we are so naive to confuse the band insulators with the other types.
Thanks for the challenge.
Re: CeRAM
resistion   8/8/2013 2:00:54 AM
Very interesting papers in Issue 109 of J. Appl. Phys (2011). So the NiO in insulating state has 4.3 eV bandgap?
nonvolatile
Re: localized conduction?
nonvolatile   8/8/2013 12:53:44 AM
Furthermore, when we lower the current in the on state by element doping, we see only the increase in the on resistance- a very desirable result, The compliance is only controlled by CO doping. It is another evidence of no filament conduction as the two currents are coming from two different mechanisms, the 3 layer data is even more controllable. This was shown 3 days ago in the MRS ISIF meeting in my keynote lecture.
nonvolatile
nonvolatile   8/8/2013 12:43:04 AM
Yes, this is true for any resistive memory. This is however a a requirement of the off to on transition. The narrow band of the TMOS is a reason for the ballistic transport. Now there is a relationship between compliance current and on current, with proper doping that saturates to low levels, even for these large areas it goes down to 100 micro amps so this very smal in nanoscale devices. So,the buffer transistor or even 1t1R this is fine. In the Array only type, the diode limits the current well. finally, current reduction was publish in another paper. I can send you a copy because It was in a conference.
resistion   8/7/2013 11:48:42 PM
Reading your 2011 papers, it seems you still need compliance, like other RRAMs.
Re: Isn't silver too expensive
krisi   8/7/2013 3:24:20 PM
To @nand_analysts: can you list those examples of failed technologies over the years? I think it would be very educational...Kris
