Differential signalling will help cut down the noise riding on the signal. But, if there is phase difference between + and _ signals, would it not modulate into phase noise ?
Thanks Ransom.....that was a good introductory session. Enjoyed the presentation
Display Port testing
HI, this class (Part 1) is audo archived (see the player above) and the slides have been updated (under special educational materials). Enjoy!
Thank you Ransom and Janine
Better late than never
Thanks Ransom ! That was a very insightful presentation !
You mentioned that  scrambling is required for 64B/66B and 128B/130B encodings to minimize the CID length. Can't scrambling alone be suffice ? Why additional encoding is required ?
Look forward to your tomorrow's class.
-Jayaprakash.
Okay, I'm outahere. "See" you tomorrow!
I've seen people manage 32 Gb/s and have heard of 40 Gb/s, but never seen it first hand on more than 3-4 inches (7-10 cm)
I don't know the answer to "How high of a data rate do you think we can get on, say, a foot of standard FR4 PCB?" I was hoping you would ; )
data rate: 250 kbps
Hi Alejandro, I'll make that request to the powers that be! It's a great suggestion. What I do know is the titles are tied to your EET profile.
What was the answer?
@JanineLove. Can we get the nicknames changed from ROOKIE to GUEST and the presenter to PRESENTER
Or, you can post your questions here and we can get to them after tomorrow's class. Thanks!
Thanks everyone for joinging in, I think we're donw. If you have anything else, send me a note: ransom@ransomsnotes.com
Yeah. I'd rather be right than wrong, so please don't be shy when you catch a mistake.
i understood, just wanted to clarify regarding tht error. Also a good presentation to revive the concepts back :)
Thanks Ashwin and Drew. Guess I spaced out while goofing around in PPT drawing utility.
It will continue to be wrong all week, I'll point it out and try to employ a different wisecrack each time.
Fortunately, one of them makes sense for feeding a VCO!
If you missed the beginning of this class, or want to hear it again, the archived audio is avaiable now.
Thank you for the presentation. Looking forward to tommorow's.
Duh.
Good catch. I wrote LPF on my PLL clock recover slide, which is CORRECT! but drew a HPF which is _wrong_
lets say slide 20, bits it mentioned wrong in all i guess.
Wow such data rates.
Thanks see you next class
slide 20 - PLL diagram - has "LPF" filter
Thank you. I have had some exposer to testing in the past and what you refer to as the eye was call the bathtub curve display on the analizer.
Have a good day very good presentation
Theo
Hey Ashwin, wich slide do you mean?
Indeed, LPF block seems to be HPF
Thanks for the presentartion
I see a lot of people doing work on advanved generations of PCIe and USB.
Wondering how you feel about PCIe no longer  requiring "distributed reference clocks."
USB 2.0
Thank you, Ransom, Janine
Thanks!, good presentation
Thanks, Ransom/Janine.
i have a question, why is LPF block depicted wrongly ?
Very interesting Ransom
Thanks Ransom for the "introduction"
Currently testing JESD204B interfaces.  Receivers on DAC's and Transmitters on ADC's
Thanks Ransom, I finally got through the firewall and was able to listen in the last 10 minutes. This was informative.
Thanks Ransom and Janine!
Nice point from Drew, we'll go into the distinction between digital and anlog tomorrow. It will involve zip-lines through jungles!
Yes, PCIe Gen 2, SFI (10Gbps).  PCIe Gen 3 on new project.
Thanks. Very good intro.
I work for a company that tests high-speed signals- QPI, PCIe gen3, USB3 using JTAG.  We are able to look at the "eye" at the dye using the embedded technology.
Dance the jitter bug, or is it the hustle?
Analog vs digital engineer - At this sort of data rate, circuit design needs both, in terms of clean power and decoupling, low noise techiques, etc.
thanks that was very good
we provide usb 2.0 applications testing on our scopes
Currently testing DP 1.2 at 5.4Gbps per channel (4 channels).  Most issues with Random Jitter and ISI loss.
usb3, dp1.2, sata, sas, fc
USB 3.0 and PCIe Gen2
Interested in hearing more about interconnect/channel impact on 28G generation
Using Chrome Version 29.0.1547.66 m. It did have some trouble buffering in the beginning, but now it seems to be okay.
I'm working on USB 3.0
USB 2.0 certification testing
currently involved in testing 10Gbps Ethernet (10.3125G)
audio just started working for me. only works in chrome and had to unplug and plug my usd headset. hope this helps. I'm using x64 machine
Using Chrome on W8x64 with no problems.
why is LPF block depicted wrong ???
Dance the JitterBug!
Do you consider yourself more of a digital or analog engineer?
I am going to leave this seminar.  IT is too hard to listen with all the audio dropouts.
Use Webex - it works for large presentations.
this topic of this seminar is really good, but the method of delivery is intolerable
I spend more time pressing play than getting to listen.
Roland, archive will be immediatly available after the live show
Chrome is not authorized web brower.  Sigh.  Guess I will wait a month or two for the recording to come out.
I can see the minus sign.
Both IE7 and Firefox do the same thing.
my audio got stable now. I am using chrome
my audio keeps stopping and I have to hit "play" many times to get it to continue
Have tried on IE as well as Chrome and it's still blocked
My pdf has a minus sign.
Load & Clear with IE7,
Too bad. This really blows but I can't hang around all day for this. Amateur stuff EE Times.
No audio.  Errors on web page.    Audio bar announces 'BlogHost Radio' then stops.   A refresh of the web page just repeat the same.
I have to press play button every 1 min to listen
The audio is working for me
Perhaps change browser to chrome or firefox, they seem to work best
no audio on my end either. just downloaded the latest flash player and refreshed a bunch of times
I still can't hear anything. Could they possibly have made this more difficult ?
Good evening from the other side of Atlantic in Valladolid, Spain; sad without 2020 Olimpic Games
we are working on 12Gbp
10Gbps in production, 28Gbps in design
I refreshed, but my player did not come up.  Still can't hear.
why do I have to keep clicking the play for audio to play. it keeps filling the progress indicator and when full the audio shuts down
then I have to click
Anritsu FAE... Supporting customers working between 14Gb/s and 32Gb/s (serial)
try refreshing, and Firefox is the preferred browser
me too...cant hear yet
@Jomo  try refreshing and hitting play on the player
Good Morning
Guten Morgan
Buenos Dias
I see the slide deck, but I don't hear a thing.
Audi is up, here we go!  Day 1!
Hello from Milwaukee!
I'm going to ask Ransom to yodel for a warm up before we go on the air...
The streaming audio player will appear on this web page when the show starts at 12:00 pm  Eastern today. Note however that some companies block live audio streams. If when the show starts you don't hear any audio, try refreshing your browser. See you in a few minutes.
Hey everyone! Thanks for showing up to class on time. No chewing gum on line, cell phones on stun.
(or whatever)
Greeting from Toronto Ontario
Theo looking forward
Be sure to click 'Today's Slide Deck' under Special Educational Materials above right to download the PowerPoint for today's session.
good morning from Ottawa, ON
Thanks for joining us today! Looking forward to getting started on this course.
Good Morning from Boston; got the slide deck as well!
Good morning from sunny Cocoa, fl
Good morning Huntsville, AL!
Good Morning from Sunny Boston!!  Little chilly out there!
Good Morning from Huntsville, Al
Great day for a radio show! Be sure to click 'Today's Slide Deck' under Special Educational Materials above right to download the PowerPoint for today's session.
The lecture comes in time I am interesting in SI and PI. Thx.
