<<   <   Page 3 / 3
Check out the ADVANCED SENSE Guide
Max The Magnificent   9/10/2013 10:47:13 AM
Speaking of high-side power switches with protection and diagnostic functions, have you read Infineon's ADVANCED SENSE Calibration and Benefits guide (http://tinyurl.com/ADVANCED-SENSE-1-0)?
As an aside... I happen to know that the guys who wrote this little rascal are incredibly clever and handsome and witty ... the words all appear to have been hand-picked at the crack of dawn while the morning dew is still glistening on them, and it goes without saying that the quality of the diagrams is fantastic...
Re: Natty devices...
antedeluvian   9/10/2013 8:48:48 AM
David
 Are these things expensive?
This is an incredibly complex question. What is a good price for me is really expensive for someone designing for the mass market. Before I overwax philosophical though, it seems to me you are only interested in a single unit, so I will only state the price from Digikey for the automotive version AUIR3314S is C$4.81. (C$1 is approx US$1.) Apparently it is still available in a TO220 pack, if you want ease of connection although you may struggle to find it in that format although I see Digikey have 6 at C$6.95 at the moment and Mouser have it in abundance.
David Ashton   9/10/2013 5:21:37 AM
Thanks, Aubrey.  I was thinking of using it on an analogue variable power supply, before the main pass transistor.  Apart from being able to switch the output off electronically, you could get a ground-referenced voltage proportional to output current - very useful for measuring output current using a standard DVM module - which on a variable PSU is otherwise not easy..  Looking at the specs for your IR3314, I think it would work  ok.  I'll look at the others as well.  Are these things expensive?
antedeluvian   9/9/2013 8:16:31 PM
Hi David
Aside from standard I/O type stuff, we have used the IR part as a form of peak current shutoff on a power supply using the current mirror to drive a comparator.
Natty devices...
David Ashton   9/9/2013 7:40:27 PM
Never heard about these before, thanks Aubrey.  I can think of a few uses for them apart from the intended automotive ones.
<<   <   Page 3 / 3
