David Ashton   9/10/2013 8:30:06 PM
@asntedeluvian: Perhaps I should do a blog on current measurment?
Damn good idea!!
antedeluvian   9/10/2013 6:40:49 PM
JeffL
 notable vendors in the low end include Allegro Microsystems and Silicon Laboratories. I'd emphasize this is for a range up to tens of amps, if you go higher into industrial motors and such you'd likely look at something like the LEM units
I have used the Allegro hall effect parts as well as current transformers and both form a part of my arsenal. I haven't looked at LEM for a while now, I will follow your reccomendation.
JeffL_2
JeffL_2   9/10/2013 5:34:45 PM
Just so happens I was looking for current transducers the other day, under Sensors -> Current Sensors on Digikey (notably NOT under ICs -> Linear "anything") and I have to admit I was immediately impressed at the array of actual application specific ICs available. You can get prices down around 51 cents in quantities of a few thousand for some configurations, notable vendors in the low end include Allegro Microsystems and Silicon Laboratories. I'd emphasize this is for a range up to tens of amps, if you go higher into industrial motors and such you'd likely look at something like the LEM units which are a space- and cost- saving Hall effect replacement for a current transformer but in a higher price product class. But I'd admit until I "stumbled upon" the previous class of chips I wasn't really aware of them, thought perhaps you folks might not be either, might want to go there and crack open a data sheet or two.
Re: Very much useful
antedeluvian   9/10/2013 2:42:09 PM
Sanjib
Do these devices require runtime calibration or one-time calibration in the factory before shipping?
The thought occurs to me that if you are reading the signal from the drivers you would be using and ADC and some additional circuitry, at the very least probably a resistor to convert the mirror current to a voltage. The ADC may also need some calibration, and it would be better is the whole thing was calibrated as a system. If you go to the second post before yours, you will find a pointer to part 1 of a blog I did on system calibration.
antedeluvian   9/10/2013 2:30:47 PM
Sanjib
You mentioned about calibration. Do these devices require runtime calibration or one-time calibration in the factory before shipping?
We would generally calibrate as part of the test process during manufacture. I don't think they need run time calibration- if one needed that sort of accuracy I would imagine that one would use some different form of external current measurement. I would add that I have only worked with the IR device. The others may be different.
Without calibration does it make a huge deviation or could the tolerance be accommodated in the firmware if too much of accuracy not needed?
I am sure you can use software to handle the variations. The current mirror ratio can vary from 4800 to 6000 with a nominal value of 5300- a variation of about +/- 10%. There is a variation of +/-5% over the temperature range and an offset of about 150mA at a 2A output. You make the choice based on your application, I guess.
If you look at the earlier post (in this thread) from Max (about 5 posts ago) he refers to an Infineon application note that actually discusses calibration of this sort of device.
Sanjib.A
Very much useful
Sanjib.A   9/10/2013 2:05:40 PM
@Aubrey, thank you for sharing information on these current sense devices. I was not aware of these devices and never used so far. But looks like I sould be able to make use of these devices in my designs. You mentioned about calibration. Do these devices require runtime calibration or one-time calibration in the factory before shipping? Without calibration does it make a huge deviation or could the tolerance be accommodated in the firmware if too much of accuracy not needed?
Re: Check out the ADVANCED SENSE Guide
Max The Magnificent   9/10/2013 11:33:35 AM
@antedeluvian: ...have you seen my current blog on calibration over on Planet Analog?
I hadn't -- but I have now :-)
antedeluvian   9/10/2013 11:10:00 AM
Max
Just going through the document and looking at section 2.5 on characteristics of straight lines. Seemed rather conicidental- have you seen my current blog on calibration over on Planet Analog?
Max The Magnificent   9/10/2013 11:03:10 AM
@antedeluvian: These are the exact same words that I saw on an old recipe for making Rose Petal Jam...
I thought you were joking, but I wen tto read the recipe (I couldn;t help myself) and saw the following:
If you're picking the roses yourself, the best time is in the late morning, after the dew has dried and before the strong afternoon sun.
I'll have to remember this recipe :-)
antedeluvian   9/10/2013 10:59:34 AM
Max
the words all appear to have been hand-picked at the crack of dawn while the morning dew is still glistening on them,
These are the exact same words that I saw on an old recipe for making Rose Petal Jam. (new recipes like this, lose the magic!) I printed the manual out, shredded it and spread it on bread- but it doesn't taste anything like jam!
Seriously though- a well written document. Infineon obviously has good taste in authors.
