JCreasey
Interesting hack of a Powerbolt....but
JCreasey   9/19/2013 7:42:01 PM
I'm not sure the use of a USB port/USB key is the best option for a doorlock.
1. USB Keys are not designed for hundreds of insertions, and the sockets not much better.
2. There is no protection between the Pi and the key so static or deliberate overvoltage could fry the Pi.
3. iSerial# is not standardized  over (or programmed into) all USB keys, so some may not work.
4. You are carrying a huge amount of overhead OS which is a risk. Can you guarantee that the OS is beyond being hacked? One assumes that the Pi is going to be hooked to Ethernet, so might be compromised from either USB or Ethernet.
I would have suggested something like the Maxim (old Dallas) silicon serial numbers would be more appropriate for this application. It has a single wire interface and costs about the same as a bargain basement no-name USB key. Something like the DS 1990 is practically indestructible (http://www.maximintegrated.com/datasheet/index.mvp/id/2829) and can be clipped into a little key fob plastic form.
The ideal IMO would be a Pi controlling (logging from) a bunch of very small micros as the door controllers. The small controllers should have inbuilt bbu for the micro and the door actuator.
PS..The Powerbolt has been hacked in this implementation, and it would make sense that the battery used in it powered the dongle device ...hard for NFC and RFID but potentially easy for the Maxim devices.
ChristophZ
Re: Very clever, but...
ChristophZ   9/18/2013 10:21:58 AM
No, you don't want biometric information as the only security barrier.
First example is the older story about the Malaysian business men:
"A Malaysian businessman has lost a finger to car thieves impatient to get around his Mercedes' fingerprint security system.", http://www.theregister.co.uk/2005/04/04/fingerprint_merc_chop/
The other example is the fact, that finger print readers are not exact enought, you have "collisions", you and some other hundred people share the same structure of your finger print (this could be avoided by using all five or ten fingers, but is this convinient?)
And of cours all the stories how easy you can fool most of the biometric systems.
To be clear: Biometric information is a very good way to add ADDITONAL security to a conventional access system (two or three factor systems).
Re: Great use of the Raspberry Pi
Caleb Kraft   9/18/2013 9:04:10 AM
absolutely. Masterlock won't be worried unless someone produces a cheap and reliable mechanical lock that isn't quite as easily picked. However, anyone that does ultimately charges much much more for it because this is a capitalist society. They know they can charge more for more security. This puts them out of the competition for masterlock.
Kinnar
Open Source Hardware is dong Remarkable Projects
Kinnar   9/18/2013 8:44:15 AM
Raspberry Pi and other open source boards are really helping the developers to collaborate and reuse the work done by others. This open source hardware has really increased the use of digital electronics remarkably.
jnissen
jnissen   9/16/2013 10:59:22 PM
I doubt it. There is still a major advantage to not having ANY electrical smarts in a lock. If you have used e-locks in the past and been locked out due to low batteries you know what I mean! Make power by energy harvesting and then you may have something.
Cool!
rick merritt   9/16/2013 7:07:33 PM
Cool!
Caleb Kraft   9/16/2013 4:18:14 PM
fingerprint scanners aren't difficult to implement but they can be buggy compared to just reading the serial number off a device. Retinal would be more difficult in a DIY type setup.
Very clever, but...
Max The Magnificent   9/16/2013 3:41:33 PM
This really is a very clever implementation, but now you have to carry a USB stick around with you -- the ideal lock has to be one that uses biometric information -- and the best of the best would be true face recognition -- how far away do you think that is?
Caleb Kraft   9/16/2013 3:08:49 PM
They have bigger fish to fry that this. Ever heard of a "Bump key"? Check out some youtube videos on that and you'll be thinking twice about your home security.
Re: Security and Safety
Caleb Kraft   9/16/2013 3:08:05 PM
Many of these were actually addressed in the wiki. For example, you aren't relying on the memory in the USB stick itself, rather the unique ID of the chip.  Obviously water and shock are a concern as they would be with any electronic component. If I recall correctly everything is in a weather proof box.
It is not connected to the cloud currently and dealing with power outages is currently handled by a fall back to a number pad, but a battery pack for the Raspberry pi is coming.
