Re: Simplest
Max The Magnificent   10/28/2013 4:46:34 PM
@jpessin: It's probably not the most efficient option computationally, but perhaps the simplest solution would be to use the Arduino language's map() function.
This just goes to show that I really need to spend some time on the Arduino website looking to see what's there. I'm currently ver yhappy with the solution proposed by Javi (Garcia) earlier in these comments, but it's great to know that this (and other) functions are available.
Re: Distance calculation ...
Max The Magnificent   10/28/2013 4:41:18 PM
@Bastian.Schick: In the ancient times we used a modified Bresenham algorithm to fade between colours...
You make it sound as though you are talking about the last millennium .... Oh, wait a moment... LOL
Re: Use fractions
Max The Magnificent   10/28/2013 4:39:53 PM
@another nickname: Your truncation problem would not be there if you stick with fractions.
True enough -- but the problem also goes away if we use the solution proposed by Javi (Garcia) in the early comments to this blog.
Re: Rounding integer division
Max The Magnificent   10/28/2013 4:38:12 PM
@DU0...01: Though the Bresenham algorithm might be appropriate...
I know this is not complex -- but I can imagine the problems that woudl ensue trying to explain all of this to an absolute beginner :-)
jpessin
Simplest
jpessin   10/28/2013 4:26:42 PM
It's probably not the most efficient option computationally, but perhaps the simplest solution would be to use the Arduino language's map() function.  It seems to work going up and going down in color value, and ends on exactly the right value, in the right number of steps.
http://arduino.cc/en/Reference/Map
This gives:
void lightLEDs (int howMany,
                int howLong)
    for (int i = 1; i <= howMany; i++)
        int tmpColor = map(i, 0, howMany, oldColor, newColor);
        // Use current tmpColor to drive LED
        delay(howLong);
Bastian.Schick
Re: Bresenham algorithm
Bastian.Schick   10/27/2013 2:50:53 AM
Sorry I did double this. But yes, Bresenham is the IMHO the best choice to move in descrete steps from one point to another.
Bastian.Schick
Bastian.Schick   10/27/2013 2:49:14 AM
Two things:
- The distance between 0 and 255 is (255-0)+1
- In the ancient times we used a modified Bresenham algorithm to fade between colours.
Cheers
another nickname
Use fractions
another nickname   10/26/2013 8:29:22 PM
Just keep 2 integers for each number numerator and denominator) and rewrite your algorithm using 2 numbers instead of one for all calcluations and do multiplications first and divisions last. It's pretty much the same as Fixed Point arithmetics .
DU00000001
DU00000001   10/26/2013 7:18:27 PM
Though the Bresenham algorithm might be appropriate, the initial question was how to cope with the truncating element of the integer division.
The solution is really simple:
result = (dividend + (divisor/2))/divisor   or
result = (dividend + (divisor>>1))/divisor
This might lead us to the next level of discussion: what if divisor is odd?
You simply have to decide whether you want to round up (x.5 => x+1) or down (x.5 => x). In one of the cases the above equations will read ((divisor+1)/2) resp. ((divisor+1)>>1).
There's always a last philosophical question or, in other words, the freedom of choice :)
Max The Magnificent   10/26/2013 6:01:09 PM
@pviry750: The standard way to do this efficiently is the Bresenham algorithm...
Cool beans -- I will bounce over to peruse and ponder the Wikipedia page on this -- I'm sure I will be doing a lot more of this in the future -- for example, with regard to my current robot project.
