BrainiacV
Portable use
BrainiacV   11/18/2013 11:37:50 AM
How about for camping equipment to keep food cool and provide lights as well as a charger?
I guess just a variation on emergency backup equipment, but I can see people buying camping equipment and then retasking it for emergencies.
What about heat? I never hear about heat generated from fuel cells in stories like this, but I hear about heat being a major factor that keeps them from being used in laptops and such.
pennyxie
Re: A great alternative to gasoline generators
pennyxie   11/14/2013 4:03:55 AM
You are very welcome. We inspired by the comments so much.
Re: Sensors, too
junko.yoshida   11/12/2013 1:17:03 PM
@Rick. Indeed, that Kionix acquisition by Rohm is definitely an interesting one. This Kyoto company should be watched closely.
Sensors, too
rick merritt   11/12/2013 12:11:21 PM
Interesting story.
I also heard recently that Rohm bought Kionix to round out its sensor line, taking on sensor big dogs ST and Bosch. Batteries and sensors are both great components for the next big waves in electronics.
Crusty1
Re: Backup power needs to be substantial to do any good
Crusty1   11/12/2013 11:47:42 AM
@DrQuine: The need is for power in excess of 1,000 watts (ideally 7,000 watts is needed to run a house). As a dedicated home solar power generator, I agree with this statement.
In the perfect world and at an affordable price, I woud like to store my surplus energy in other than lead acid batteries, if i could split H 2 O with electricty to O2 and Hand use it in a fuel cell during nill geneating hours then I would be a happy bunny.
As it stands now I dump any surplas electricity into the hot water tank, which is best suited to solar water panel heating.
junko.yoshida   11/12/2013 8:29:39 AM
@pennyxie, thanks for chiming in. Nothing like hearing from Rohm's researcher. Again, thank you for adding perspectives here.
pennyxie
pennyxie   11/12/2013 3:08:28 AM
As you said, CaH2 making process is frustrating. if people can make CaH2 with recycable  energy, it will be a little bit better in terms of energy efficiency.
And yes, CaH2 can be in power form, but it strongly reacts with wate to release hydrogen which is very difficult to control. We coating that with special martiral to keep it release hydrogen gradually and keep it safe to use.
DrQuine
DrQuine   11/11/2013 7:32:03 PM
There certainly is a need for clean, inexpensive, portable emergency backup power. The need, however, is not to charge SmartPhones (which can be charged in a car or run off a small battery) or run 5 Watt LED lights which run for a long time on a battery. Small amounts of backup power (as 12 volts or inverted to 120 volts AC) can also be obtained from the cigarette lighter in a car. We do so every time we have a power failure at home.  The need is for power in excess of 1,000 watts (ideally 7,000 watts is needed to run a house) that can run refrigerators (the start-up current is substantial), home heating systems, and the like. Only an emergency backup system with such power levels will have a substantial market.
junko.yoshida   11/11/2013 5:42:01 PM
Bert, understood. Agreed.
Bert22306   11/11/2013 5:21:08 PM
Right, but that's like all fuel cells. The "no CO2" showing on the right is a little disingenuous, since you'll be creating CO2, more than likely, in the making of this CaH2 fuel.
That gray block on the left of your graphic is where the CaH2 fuel has water added to it, to make the H2 for the fuel cell. The chemical reactions I posted previously are what is needed to make that CaH2 fuel to begin with.
