abraxalito
Re: On a more philsophical note.....
abraxalito   11/19/2013 8:41:51 PM
How about a question with the same word count - 'Can digital cables be audibly different?' ?
MeasurementBlues   11/19/2013 9:15:10 AM
'I currently know of no way for a digital cable to make an audible difference'.
Too long for a title, but perhaps in the text. We agonize over titles because they must be short, yet have enough info to get you to read.
abraxalito
Re: You're assuming a perfect DAC
abraxalito   11/19/2013 7:19:03 AM
Galvanic isolation is a step in the right direction - however its only providing perffect isolation at DC. Check the interwinding capacitance of your S/PDIF transformer - the ones with the best isolation sport a figure <1pF. If yours is higher you still might gain improvement in fitting a CM choke to your cable (or clamping on a ferrite). Also check to see if internally there's a dedicated ground wire going to the digital input termination (75ohms) from the mains trafo secondary. A lot of DACs just use their internal groundplane to carry the CM noise current, impacting the sensitive analog circuits using that groundplane as their 0V reference.
ChristophZ
ChristophZ   11/19/2013 2:27:05 AM
That is one reason why I prefer optical cables over the coax variant, you get a proper galvanic isolation between the high frequency digital device (TV, Blueray Player, PC etc.) and your analog system (The DAC has to be designed like a analog device...).
My DAC at home is from the studio market, not consumer, it has a galvanically isolated coaxial input. This helps too to control the output signal quality independent of the cabling in use (lenght, noise on the way).
Re: Audioquest is garbage
David Ashton   11/19/2013 1:44:14 AM
@bob.....this is, as you say, garbage.    Unless there is a lot of noise, crosstalk or some other very good reason, these cables will perform no better than the ones you buy at the $2 shop.
However....the guys who can sell these cables to the people with more money than sense will wind up richer than all of the posters on this column.  If they can do that, good luck to them.  Why didn't I think of this? :-)
bobzz0
bobzz0   11/19/2013 12:47:13 AM
I hope this cable is better than the audio cables I have tested from Audioquest. Audioquest RCA audio cables exhibit significant microphonics, so much so that vibrations from my home theater subwoofer created an oscillator. Yes certainly on long runs cables can be a factor in digital AV, but the garbage I have seen from Audioquest is not tha answer.
abraxalito
abraxalito   11/19/2013 12:14:40 AM
Your title here is an example of denialism. Based on what you write in the piece, a more accurate title would be 'I currently know of no way for a digital cable to make an audible difference'. Surely engineering is about finding ways to deliver satisfactory products to customers - if the customers are hearing someting then its our remit to explore the reason for that rather than lapse into knee-jerk denials of what they say they hear?
abraxalito
abraxalito   11/18/2013 11:53:45 PM
Whilst its demonstrably true that digital cables don't change bits, they can and do present different common-mode impedances to RF noise in a system. Many DACs are sensitive to common-mode noise on their digital inputs due to poor grounding and noise control design decisions - so that for example adding a ferrite clamp to a digital cable can make an audible difference.
chanj0
Re: HDMI, on the other hand...
chanj0   11/18/2013 9:17:13 PM
As far as I remember, HDMI delivers data in differential pair. They have to be separated otherwise the integrity of data is going to be affected.
MeasurementBlues   11/18/2013 2:01:26 PM
@betajet, I've done some studies of cheap Apple knockoff 30-pin connectors. One of the says the knockoff save money is my using vewer ground pins than Apple. If you like, I can post them here.
In conjunction with unveiling of EE Times’ Silicon 60 list, journalist & Silicon 60 researcher Peter Clarke hosts a conversation on startups in the electronics industry. One of Silicon Valley's great contributions to the world has been the demonstration of how the application of entrepreneurship and venture capital to electronics and semiconductor hardware can create wealth with developments in semiconductors, displays, design automation, MEMS and across the breadth of hardware developments. But in recent years concerns have been raised that traditional venture capital has turned its back on hardware-related startups in favor of software and Internet applications and services. Panelists from incubators join Peter Clarke in debate.
10:29
