Great stuff, although I am going to have to work though this session at least one more time. Gotta love archived material!
Thank you DavidWR for that comment. Got it sorted.
with FPU-VFPv4, measured at PG14 frequency=58.8k period=17us; with FPU=none, f=35.7k T=28us
Thanks for the archives!!
For those having trouble with ST-Link
The ST Link interface needs to be set to "SWD" ...
So on the project right click on the Project - "Name"
Choose Debugger -- make sure it Says STLink
Then Choose the Option for STLink underneath and make sure it is  et to "SWD"
drw36 and nicholasfillon: Thanks for the response!
Will double check my steps, but I did copy main_step4.c to replace main.c and X'ed old main.c out in the build. Also added Cycle_Counter.c/.h but I will double check those too. So you guys did get entire Step 4 exercise to work with out the TimerCount_Start/Stop, I take it?
I must have missed something. Guess I will just have to have another go at it...
@achen95132
The ST-Link/V2 is on the STM32F429 Discovery Board (32F429IDISCOVERY) used in this class, Can you post more details of the issue you are seeing.
Also see 'Setting up the STM32F429 Discovery Board for Sessions 3 to 5 hands-on workshops' (PDF) above and here http://www.st.com/web/catalog/tools/FM116/SC959/SS1532/PF259090
At the beginning, I wasted a lot of time figuring out why ST-link is not working for me.
Finally, I realize it requires additional piece of hardware ST-Link/V2.
It would be nice to make it clear from the beginning of setup.
@Alan, be sure to have selected the ST-LINK in your debug section of the option of the project under EAWRM, in the options of the project, go to Debugger, then select the tab download and make sure the "use flash loader" is checked
@ajbieee: do not foget to copy: main_step4.c, Cycle_Counter.c, and Cycle_Counter.h into the FPU directory where you have the source files. and then add these files into your project under IAR EWARM, then exclude main.c from the build
@Jose_Avila  Thanks for the reply.  I have tried that.  In fact the olnly place I can't get a break point is at main?  I just get a red circle and a ding.  Not a dot.  The toggles do the same thing.
@ajbieee - Did you follow the steps from bullet 5 slide 20 through the exclude step on slide 21? Did you miss excluding main.c or forget to copy the .h file?
Anyone else run into this error?
Error[Li005]: no definition for "TimerCount_Start" [referenced from C:\STM32Seminar\Projects\Peripheral_Examples\FPU_Example\EWARM\Debug\Obj\main_Step4.o]
Error[Li005]: no definition for "TimerCount_Stop" [referenced from C:\STM32Seminar\Projects\Peripheral_Examples\FPU_Example\EWARM\Debug\Obj\main_Step4.o]
Error while running Linker
(also at the end of Slide 21)
At the bottom of slide 21 when I run download and debug I get fatal error. "Failed to load ftd2xx.dll Ensure that the TI Emulation package..."
All steps prior to this worked fine (e.g. looking at the code count differences between FPU/noFPU
Also,  can the chat area have an option to add at the bottom?  Trying to read while new comments cause it to jump down is quite difficult.
I also think the format of this presentation was a great idea.  I've been to several of these seminars throughout my career and this was the best because I didn't have to leave my office.  I hope ST, Digikey, EE Times and others will do more seminars in this format.
@steve61 just click to the left of the line number
Sorry, late start.  Got to slide 21, everything look great, but won't let me set a break point.  Just get ding.  No error messag?
Hope someone is still there.
Steve
Yeah...mine says 72 MHz too...
@michaelcossen. You can find/edit the CPU clock by going to:
Project/options/ST-LINK. ST-LINK is the debugger used for this board.
See you tomorrow folks.
Nothing at post office... maybe UPS?
It looks like system_stm32f4xx.c defines the system clock speed and is set to 180 MHz.  I just saw a couple of references inside the IAR environment that indicated 72 MHz, which I believe is the F3 series max clock speed.
Sorry for the delayed response.  I was looking around in the Options inside IAR Workbench.
@michaelcosson: which file are you looking at?
I have just been poking around in IAR, and it appears that the STM32 is set to 72 MHz, instead of 180 MHz?  Is that right?  If so, how can we change the clock speed to 180 MHz?  Thanks.
I just got an email from EETimes that UPS has a delivery confirmation for Monday at the office. I am going to have to talk to someone at the office about sharing information like that.
Thank you for the great session.
I just wanted to mention that I, too, will need to get my STM32 [GCC?] toolchain+IDE (etc) up and working under Linux. And also under something not altogether foreign from a dev perspective, Mac OS. cc STMicroelectronics!
Using a LogicPort logic analyzer:
FPU off, no opt: 14.36 us
FPU off, opt (max), removed SysTick calls: 12.46 us
FPU on, no opt: 9.16 us
FPU on, opt (max), removed SysTick calls: 7.61 us
Will check the post office.
Clearly someone does not understand the Canadain mail system. :-(
Canada (Mississauga) here. Finaly my board is here :)
It's Canada post.
6 december: item has left US.
9 december: item has arrived in Canada, Mississauga.
After that it took 3 days.
Made it through the Simulator example (Step 3) and about ready to download the (Step 4). Just really need to be able to take your time and the slides will get you there as someone else just mentioned.
Guess I will finish up Step 4 here and stop for now as Step 5 needs me to fire up my scope anyway (now where did it put that thing :)
Thanks   for teh LINE EDITORS !!   The issue that i see is the "getting redy from session 2 to Session3" -- IAR enviroment options, and setting such line numbers, and  features. After that Session 3-4-5 can be done. Knowing the Enviromnet help.  I know some folks here they are already using IAR so they know what to Click!!!
Thank you all and see you tomorrow.
I think this whole course concept with the hands-on hardware interaction is a GREAT idea — thanks Jacob, ST, Digi-Key, UBM, et al for making it possible! (and for being willing to try out this experiment in the first place)
Okay I will look into that meanwhile I am using what ever is already in Chrome.
For now I will just use another machine to record the audio or even go to tape and then digitize it.
Thanks!!
Thanks much!!  Love those line numbers :)
Windows Em:Blocks IDE has the firmware examples of the peripheral library setup (link on their forum), and  debugs of ST-Link
ST should talk/pay them to port to linux and supply on a flash-drive for their seminars. Would save 45 minutes installing Gigabytes of IAR
Tools -> options -> editor -> show line number
geraldfryjr
I have read on another chat that realplayer will let you save the audio stream to your local machine. I haven't felt a need to try it myself.
Is there a way to enable line numbers in the source code window?
@GaryS471: Are there some tools around to convert/import  an IAR or KEIL project to CoCoxx/Eclipse with GCC?
If oonly... their MDK importer is for Version 1 or something -- I could not get it to work.
Don't have my board yet -- will try then.
I usually move projects by hand into or out of IAR. It's not that tough -- but you have to learn IAR to understand what to do -- either way.
If you have the $$$ -- IAR is the Gold Standard. (In case you are in the 1% wh don't know.)
It would be nice to be able to download the wave file of the presentation available so that it can be played localy without the use of the internet as some times it gets glitchy in my area even though it is highspeed.
I also got  way far behind at the "Options" selection. It wasn't clear that a portion of the code needed to be highlighted first.  Also, I had trouble following at the bottom of slide 20 - I didn't know how to place the code into the 'working directory', and spent quite a bit of time trying to find that directory using WindowsExplorer, instead of just dragging&dropping the code into the source tree within IAR.
Thanks again Jacob.  I see now that those of us with limited experience should listen to your lecture to note the main points, then step slowly through the archived material to gain an in-depth understanding of this system.
Thanks EEtimes, Jacob, Rich, Digikey et. all. This is a really good way to introduce a new product and get into the hands of embedded designers. The only suggestion I could make is to help provide easier access to a free(open source) or low cost  toolchain with specific support for the family. This is important for us small guys who don't have a lot of time to tweak existing tools.
@MELANGILLE you will need to use the 30-day eval version
@Jacob_Beningo: btw, do you know why is it that you're so time-confined? (I'm familiar with the designnews series, so it's not new to me, but I never quite understood why quite so very limited, particularly as clarity of educational instruction seems like it would be the paramount consideration)
Can the code size version of the IAR workbench be used or do you have to choose the 30 trial version?
For tomorrows session the slides and examples are available for you to preview
Exactly!  We have 30 - 40 minutes so between the slides and the recording the hope is that everyone can follow along.  Worst case it's just followed up after the session.
@alive
SO in assembly there are specific op codes that are used when the FPU is enabled versus emulated when not.  So unless you write in asembly, it will be hard for the C compiiler to do this.  There are specfic exceptions and ISR for the FPU, you can monitor those.  These are explained in the App note for the FPU at www.st.com/stm32f4.
Another update on reloading the demo program. I just reloaded it after this webinar session, and the day-of-week was only wrong on the first pass (showed Mon instead of Thurs). When I reran it, it correctly showed Thurs for 12 Dec 2013.  Cheers.
I appreciate the fast pace.
Also, the slides are complete enough that you can go through them successfully even without the audio.
so, easily fixable, as I see it: I'd recommend either
  • assembling the customized project src bundle(s) ahead of time for each stage
  • else, if that's not possible at this point, write up and email to everyone this evening those parts of the instructions such that we may get that all prepped ahead of time
Thanks - this is good info.
My only suggestion would be to update slide 13 to add the trick to get the linker options to show up.
IAR has excellent videos and tutorials -- see the Information centre (Help menu)
and their web site.
I rember starting out with it -- I felt trully lost for a week or two. And I used to use Eclipse and Cygwin -- so go figger! ;-)
Hi, If you need more information on our MCU offering please go to: http://www.st.com/web/en/catalog/mmc/FM141
Is there any way to force some part of the code to run in the FPU instead of letting it be done automatically?  Howe can one check which part is running on the FPU?
Ahh yea I'm using a i7 with 16 GB or RAM so the assumption that when I'm done compiling everyone else is is a bad assumption.  Thanks for mentioning this as I will keep it in mind next time!
Thanks. Would have been helpful to see a live screen as Jacob was going through the steps making it easier to follow what was going on.  Can't wait to get the kit for some hands on.
Due to time I had to go a little fast but ....... please listen to the recorded session and pause as needed!
Thanks, good presentation- a bit faster than my machine for compile/etc. so I was always way behind, but I was able to keep track and get it done.
@mike_impossible
check out www.st.com/stm32f4, app note for FPU.  There is a full dsp library also in our standard F4 library.  This is form arm.  Check out www.arm.com, the docs are there on how to use the DSP library in our standard library.
Thanks for the presentation. I look forward to working through these projects when the board arrives.  I can sympathize with those who are truely new to the discipline and offer the advice to work the projects on this and other processors so that it becomes familiar. I have been using these devices for decades and could follow even though I never used this family of processors.
Cool! thx. it's working now! 1569 cycles :)
Great session! I had a little trouble keeping up, but I got the gist of it. Having a functional board really "brings it home". Thanks Jacob and ST!
One of the exiciting things about this course is that it is a hands-on course online!  I think this is the first time many of us have tried something like this so expect it to only get better in the future!
Good session. Limited time, so it has to be quite dense. Lots of example projects to explore. Written instructions very clear. As an non-US, non-Canadian, non-first-1000 viewer, I'm impressed with this very cheap, very powerful MCU board. Ordered it from RS Online. Got it next day.
Many thanks.
@jxsb  Yes, IAR can execute code in simulator mode without the need for target board.
re things moving too quickly for us to follow along—I have to reluctantly agree; but I think really, it's the misc shell etc activities (eg locating files in a *different* FS subtree) are really what the problems stem from—I must confess, I'm the last person to be imagined in this situation (everything prior was way too slow for me) (and also, I went and followed through the first few exercises in the slides last night)
CooCox forum notes lik for this board:
http://www.coocox.org/forum/topic.php?id=3714
Not perfect -- but it is free.
Thank you. It was interesting lecture. Audio was good but no board.
Shame my board I ordered here in the UK did not arrive. Anyway, following it ok. Thanks for the presentations.
Thanks to EETimes and Rich, Jacob, STM, ...  Looking forwwrd to the graphics presentation.
I HAVE TWO STATION, ONE JUST TO SEE  THE CHAT WINDOW AND SLICE, THE OTHER JUST FOR THE DEVELOPMENT, AND STILL I GOT LOST,  A VIDEO STREAMING WILL HELP SINCE WE FOLLOW, IT  IS  SO SIMPLE TO CREATE ONE, GO TO JUSTINTV, USTREAM, OPEN A CHANNEL, AND UPLOAD WEBCAST ... THEY HAVE ALL THE BANDWITH
Thanks, informative session.
Thanks Jacob, once the audio had an opportunity to cache it worked fine, even if I was running about 4 minutes behind everyone else judging by the chats.  SysTick worked fine, will do the IAR sim now and be back for the graphics tomorrow.
** To all who've commented on Audio only. We do appreciate the feedback. This was a first for all of us and we'll learn from the experience. **
Thanks,  I had some issues with IAR workbench due to pre existing installs, but other than that all has been good.
Thank you everyone another informative lecture.
@Garys47a
The GNU stuff does seem to lag the new parts.  The F429 out a couple months.  Assume it will be there shortly
Thanks and you are welcome!
@e7, please verify that you have the flash loader enabled. open project options->Debugger-Download
make sure that use flash loader check box is checked.
Working my way through the slides now...just takes a little time and if you miss something like making sure that the root of the tree is highlighted it really slows you down ;)
I would think if speed and power are an issue floating point should be avoided if not necessary?
this is very good seminar. Nice going.
COOCOX can support this chip. See the notes in the FORUM at their site, It is not straightfoward yet -- it can be made to work.
@rwilliams, you are correct, it is a global
Thank you Rich, EETimes, ST and Digi-Key
are there docs available to learn more about using the DSP?
@craig429
FPU does use more power.  There are also exceptions that need to be handled.  The Push/Pop are longer in/out of ISR.  Other than that, it's there use it.
Thanks Jacob & ST. it is certainly a challenge to do a lab session with audio ony..
Haven't tried with optimizations on!  It would be interesting to see but results will vary from compiler to compiler
Session was very informative..thanks Jacob
CoCoxx - Does not yet support F429
Thank you Jacob and EETimes.
Thank you, Jacob, ST, and EETimes, the presentation was excellent.
?How is the code dvided into the part that goes into the FPU and the part that is not?
FPU could use more power  vs. more CPU instructions
Jacob, another informative session ... Thanks !
Thanks.  A lot to digest, but really good stuff
Have you done the comparison of FPU vs library with optimizations on
Thanks for your time and attention everyone!  How are the labs going so far?
I can't go into debug mode:
Verify error at address 0x080001A8, target byte: 0x01, byte in file: 0x21
fixed point vs. floating point   less costly s/w development and test
Really need to have live video to follow effectively.
Can the IAR simulator execute the STM32F4 project code without requiring a target board?
Thanks Jacob and EE Times.
I agree with all that are struggling to keep up.  Lost you at hand on activity slide 13
Good presentation. Thanks.
Thank you Guys, fun stuff
COOCOX is a free IDE -- see my notes in lecture ONE
@theokowd
The F429 has hardware Floating Point Unit which does IEE floating point.
IAR is IDE tool
Systick as a 24 bit time in the Cortex M4F core running at core frequency
Very Cool Stuff!!
Thank you Jacob!!
Is there any reason when to not use the FPU?
great presentation, many thanks!
I was late, but you are great anyway.
Thank you.  I can breath now.
looking forward to the graphics labs. thanx
** Thanks for attending. We're here to take your questions. **
See you tomorrow!!
Can you name some examples of where the floating point math would be used versus finite point math in embedded systems?
What about a free IDE for these nice devices
Those having trouble
Work the labs in advance
Awesome presentation. Thanks!
Why does TimerCount_Stop pass nb_cycles as a parameter? It isn't needed.
STILL !!!!!!   THESE ONLINE ARE GOOD IF THERE SI A VIDEO STREAMING!!!  SO TAHT WE KNOW WHAT IN THE WORLD THE PRESENTER IS CLICKING .... AUDIO IS NOT SUFFICIENT WHEN DEALING  WEBCAST. SPECIALLY SETTING UP AND WORKING WITH EXAMPLES.
What is the meaning of FPU, IAR, SysTick ? More time is required. Time is too short for the content is very complex.
Theo
@wilfredo.henriquez the archive will be available to follow along long later
BETTER A VIDEO --- STREAMING SO TAHT WE FOLLOW AT LEAST
JAJJAJAJ ---- For these online, we need more time --imposible to follow !!!!  ONLINE LABS SHOULD BE 2 HOURS AND SLOW
@drw36 In debug: View -> Auto
LOST now. where is AUTO?
You cant display until you run debug
Any time I open one of these workspaces, the IAR workspace is totally gray and menu options are not working.  the application also crashes frequently.  Should I reinstall IAR?
Bottom line: 37-40% performance improvement in using the FPU hardware
Enable the EWARM Simulator
– Project ? Options ? Debugger ?Setup ? Simulator.
@drw36
ALT F7-->Debugger-->Driver pull down, select Simulator not STLINK
Guess this will have to be an 'off-line' activity to compare the software/hardware that is summarized on Slide 27...
I'm having to type fast to keep up
I don't see a simulator to choose. list empty.
@Atchi
There is a Generate Linker map file checkbox in Linker->List tab
@ajbieee, good news, let us know if you have other issues
Yeah...finally found the Linker...
To be able to open the the project option you need first to highlight the project: FPU - Debug then right click on it and go to options
@jjulian274
Make sure the FPU project is the active one
@jjulian274 - be sure to highlight the project name in the tree first.
I CAN NOT GET  THE OPTIONS  FROM BEEN GREAY OUT ...  PROJECT OPTIONS ---
– Project ? Options? Linker ? List ? 'Generate Linker map file
I dont see linker in options..!!!
Which memory size is RAM and Flash?
My project->options has none of these fields.
@Mike.haley, try disabling the READ attributes for the folder
@rob_young
Alt +F7 to open project options,
Linker->List->Generate Linker map file.
be sure open the right project: C:\STM32Seminar\projects\Peripheral_Examples\FPU_Example\EWARM\FPU.eww
Yeah...no Linker on Project -> Options either
Need help getting linker option
IAR, Windoes gives me errors that it can't find "C:\STM32Seminar\projects\Peripheral_Example s\FPU_Example\EWARM\FPU.eww" even though the files are there and I can see them in Windows explorer.
he lost me - how do I get to the Linker options?
@wilfredo: I see wnhat you are missing: we wrote a section on this in the user manual, please go to Help -> Help Content, then go to the section 4.8 Code configuration and generation page 29
audio perfect in FireFox
Audio keeps dropping and I have to restart the stream
GNU Octave link:
http://www.gnu.org/software/octave/
With apologies to any MatLab reps listening in...
@nicolasfillion  I got  that what is missing the steps are how you used on the project, one example step by step is what is messing from session 3....
Audio keeps dropping for me and I have to restart the stream, never had any issues before, but I may just have to wait for the archive to post at the end of the session today
For those who cannot afford MatLab there is always GNU Octave to help with the math like IIR filters etc.
I use it on Linux and Windows.
Did not receive the board yet and no audio...
I will evaluate it at home when the board arrive.
Thank's
Robert Lessard, Saint-Eustache (cold here to !)
@wilfredo, the MicroXplorer is going to generate 3 files that will configure the GPIOs of your application:
src
mx_gpio.c
mx_main.c
inc
mx_gpio.h
the idea is to add these files into your project and add them to the project files.
And call the mx_pinout_config(); function at the beginning of your main function.
Audio- widget appeared for me after refreshing ctrl-f5
Theo from Canada Ontario Toronto
I have not gotten my board yet. But am on line without audio to read your slides and read the chats.
RichQ,
No, I can get the slide deck but no audio.  It used to work.
Chip, were you able to access the archive?
davidwr, thanks. Great info.
Cold here in Central New York.
No audio again.  Didn't have any yesterday either.
Not yet! however I am geting exposure and will later in time follow up on the course. Being able to referance the achieve and course material is perfect for delayed  comuniations situations. I still have no audio and am on line to read the chats and overview the slides POWER POINT. A network proplem for the audio still continues. I have three WorkStations and all are in order.
Theo from TO
haven't received the board. any tracking number? from UPS or?
ajbieee  try refreshing
Oh...there it is...it just appeared...
Hello from St-Basile, Québec. No Kit so will try to follow anyway.
Mmmm...no audio feed coming up today. Is there a problem, Houston?
Ssession 3 left an unknow  with MicroExpolore
what do you do with the Source Code of teh configuration
and where do you place this configuartion on a new Project.
It is graet that we can configure all the Pins to avoid issues
in multiple funtions pins, but where and how do we use these files
Good Morniing.  Can't wait for some hands on.
Kinda expecting that this DSP demo will take that FPU up to 100% utilization today...
I'm enjoying them too!
@lowfreq:  First get the COOCOX tool chanin and try that -- it will provide some answers -- assuming you are using windows.
I have used the ARM tool chain (Launchpad) and eclipse for the editor successfully -- but I used Cygwin for the compiles due to the makefiles only running correctly under cygwin (or mingw).
I left some info on the first days nortes re coocox. with links.
Hello,  Really enjoying these and the board.
Hi from Birmingham!
Hello everyone!  Looking forward to the 4th installment in this lecture series :)
hi all, still no board delivered =(
Devad, Sorry you having issue, just installed on Win7, STLINK driver comes up under OTHER devices, had to uninstall, and manually install, took care ofthe problem.  Check out the help slides, there are specific instructions.
I am very new to putting together toolchains. I have used IAR  before and that is
up and running. I have tried to get Eclipse to play nice with Code Sourcery Lite following a couple of prior online blog post. No joy yet. I am hoping that someone more knowledgeable will post a setup for freeware C/C+   toolchain with support for stm32f4xx soon.
Hello every one from Jackson Michigan!!
This is the part that I have been waiting for...DSP's !!!
Board fired up and idleing around 2-3% utilization with the default demo program reloaded from yesterday here in North Carolina
-The streaming audio player will appear on this web page when the show starts at 12:00 pm  Eastern today. Note however that some companies block live audio streams. If when the show starts you don't hear any audio, try refreshing your browser.   Also, Firefox and Chrome seemed to be the best browser for listening.
Hi from Santa Rosa, CA
Hello from chilly Florida
Season's Greetings from Michigan!!!
Some people are having trouble with the Demo Program I see -- a bug.
Maybe if we ask arround there will be a programmer in the group to fix it.
Hello From Raleigh, NC.    Jacob thanks for these great lectures!
Good morning from Hamilton ON - no board yet :(
Hello from sunny SE lake Simcoe Ontario Canada.
Nope no board here either...
Hi everyone, having fun playing with the board!
did anyone in canada get the board yet?
@theokowd - Have you received your dev board?
Hello Everyone from TO, ON,
 Canada
2003 Xp and it did not un-zip
@Rodney0 - if yiou have the zip file from above. Yes that is the right zip file
Warming upin Cotati, Ca
From Canada here. I havn't received my board yet. :|
Good morning from Greensboro, NC.
GM from Sunny FL, where it is well..... warm!
ST_Laurent_McLaren, I found the zip fila, maybe I cant open it
Greeting from frigid Boston!  Brrrrr
Greetings from Vermont, 16F and clear sky
Hmmm...now that I updated the time, the rebuilt demo program correctly shows the day as a Thursday.  Weird.  So it was only intially the day of week was wrong???
fredrik, the Outlook calendar item that gets sent puts the reminder setting at "none" so it won't sound a bell or anything unless you change that setting in your calendar. At least that's how it has been working for me.
@rodney0 are you following the instructions in 'Setting up the STM32F429 Discovery Board for Sessions 3 to 5 hands-on workshops (PDF)' - see link above the chat window
I confirm what @DPC1E said for the rebuilt demo program -- the calendar for today (12 Dec 2013) INCORRECTLY shows as Monday.  I also noticed the icons were a little different.  Can we get one without the bug?
good morning from Lebanon Oregon
Hello from Albuquerque.
Good Morning.  I didn't get a notice yesterday either.
I didn't get a reminder about yesterday's class.  Anyone else miss that?
Good Morning.  Any suggestions on my STLink download problem ? I post my details last night.  Thanks
I cannot find the WARM 6.7 or the download for the other demo files
help please
Thanks Jacob and the sponsors for a great course.
Per an earlier post yesterday I rebuilt and loaded the initial demo program.
It is a bit different from the one delivered with the board.  The icons for the
clock and game are different and there is a bug in the calander in this version.
It shows Thursday, 12 December 2013 as a Monday.  Where can I download
the project delivered with the board?
Slides good, Files O.K. now I hope to get a device a.s.a.p.
so I can get started now. ... I have a usb cable.
Slides when you can, please.
EE Life
Max Maxfield
ESC Boston 2015 Sneak Peek -- Awesome Analog Meters
Max Maxfield
Post a comment
Almost any information that is captured by a sensor or generated by an electronic or electro-mechanical system can be displayed in analog or digital fashion. A common example with which we ...
Martin Rowe
Leonard Nimoy, We'll Miss you
Martin Rowe
2 comments
Like many of you, I was saddened to hear the news of Leonard Nimoy's death. His Star Trek character Mr. Spock was an inspiration to many of us who entered technical fields.
Rajaram Regupathy, Cypress Semiconductor
Add USB Battery Charging Protocols to an Android-Based Design
Post a comment
Editorial Note: Excerpted from Unboxing Android: A hands on approach with real world examples, by Rajaram Regupathy, the author takes you through the process incorporating effective power ...
Rich Quinnell
Rich Quinnell
16 comments
10:29
EE Times Senior Technical Editor Martin Rowe will interview EMC engineer Kenneth Wyatt.
