<<   <   Page 3 / 3
Ephi2014
Re: 39 GHz in your smartphone
Ephi2014   1/11/2014 9:21:09 PM
If they would improve the battery life of thus damn smart phones ,
Les_Slater
Les_Slater   1/11/2014 7:50:52 PM
Interesting question. Very few, if any, could have foreseen where we would be today, let's say 50 years ago in 1964. But I think we might be better equipped to approach the question going forward.
How much data do we need local access to? For instance, would it even be desirable to have all financial transactions in the world, on a real time basis, go through our personal mobile device? It would need to be a very powerful mobile device to make use of such enormous quantities of data. I'm sure we could find more efficient ways to get the desired results.
The real question is how much unique information could be available to a mobile device that would be useful to transmit? These could include biomentric information, precise location and orientation information and various user inputs like voice, camera, keyboard etc. And what information needs to be received to present, control, or otherwise be useful.
Another is that each mobile device, or other categories, could be a peer to peer part of some sort of mesh type network. But even here, maybe especially, each node would carry a small part of aggrigate traffic.
I believe the future will bring better understanding of how much data personal mobile devices need and there will be a useful limit, not defined by RF capability but by utility.
daleste
daleste   1/11/2014 7:42:27 PM
Its just like everything else.  We will always push for more.  If the cost structure will support it, then 5G will succeed and I doubt it will be the last.
Caleb Kraft   1/11/2014 3:19:55 PM
Aside from the definition of what 5G is, do you honestly believe there will ever be a point where everyone just sits back and says "you know what? We've got enough."?
Les_Slater
Re: 28GHz or 39GHz - Is this mm wave?
Les_Slater   1/10/2014 10:31:00 PM
If I'm doing my math right then 39GHz is 7.7mm and 28GHz is 10.7mm. Sounds millimeterish to me.
_hm
_hm   1/10/2014 9:48:57 PM
I wonder can we call 28GHz and 38GHz mmwave?
Les_Slater
Beam forming phased array antennas
Les_Slater   1/10/2014 7:58:16 PM
28 or 39 GHz will not work in all scenerios but will in many. Beam forming will be key at both the mobile end and at the base station. Also terrain mapping for reflective surfaces in urban environments as well as attenuation factors through walls.
The mobile device will need higher accuracy location mechanisms and orientation info to report to base stations so beam forming will be colabrative effort.
Seemless handoff of course, not only geography, including obstructions but bands too.
Yog-Sothoth
Yog-Sothoth   1/10/2014 7:37:25 PM
Given that even 2.4GHz wifi works with a range of about 5 metres max in my house due to the nature of the walls,  I don't think 60 GHz will really cut it.
I could not get a cellular signal from a 1800Mhz provider in my house , despite being less than a mile away from the base station. Only a 900Mhz signal would go through the trees in the way...
"Ye canna change the laws of physics" as a certain engineer once said...
krisi   1/10/2014 5:15:33 PM
Rick, how is 5G defined? 4G is 1 Gb/s throughput for stationary links I think, what is the corresponding number for 5G? and why do we need 5G? isn't 1 Gb/s enough? do we need to watch HD movies on msart phones? Kris
rick merritt   1/10/2014 12:56:40 PM
OK, wireless engineers, I'd like to hear what kind of challenges we will need to tackle to get to a 2020 smartphone that roams from 2 and 39 GHz for cellular service.
<<   <   Page 3 / 3
