Re: Impedance
David Ashton   2/13/2014 1:43:51 AM
@sukeshv - "How can that be related to PCB environment..??"
Good point - we do tend to get off-topic here.   Betajet's explanation is good - PCB traces approximate to 50Ω and it is (happily) a commonly used impedance.  But it will vary with the thickness of the board, track size, etc as Betajet points out.      Also ECL - for years the predominant high-speed logic family - works at 50Ω as well, maybe that has something to do with it?
sukv
Re: Impedance
sukv   2/12/2014 11:47:15 PM
Folded dipole ,its relating to antenna right ? - the device which radiates energy.
How can that be related to PCB environment where radiations are not at all allowed ?
Re: Impedance
David Ashton   2/12/2014 3:26:50 PM
HI Glen.   "The tale I heard is that a 1/4 wave vertical antenna on a right-angled ground plane is about 36 ohms, and a non-folded dipole above the ground effect is about 72 ohms.  50 ohms is a nice round number in the middle."
That's funny!  SWRs don't worry about round numbers, and with most antennas you can get a really good SWR with 50Ω cable.
I think the natural resonance of a folded dipole is around 50 ohms, so that's why 50 ohms is so commonly used.  But TV antennas seem to use 75Ω, as do satellite dishes.
I remember my comms textbooks had a lot to say on this subject, but they are back in Zimbabwe - possibly.......
zeeglen
Re: Impedance
zeeglen   2/12/2014 3:09:09 PM
Why exactly are we using 50 ohm impedance ?
A 1/4 wave vertical antenna with a ground counterpoise angled downwards (such as might be found on the rooftop of a ham radio operator) is a very close match to 50 ohms. When properly tuned mine usually measured better than 1.1 to 1 standing wave ratio when fed with 50 ohm coax cable.
Re: Impedance
krisi   2/12/2014 3:03:20 PM
The trade-off is between dieletric breakdown and power delivered to the load...for a fixed inner conductor diameter one could increase outer diameter to increase breakdown voltage...but the characteristic impedance would increase and that would make power deliverable to the load smaller...so there is a well defined ratio of the of conductor diameters that maximizes power handling capability of the impedance of the coax
Re: Impedance
betajet   2/12/2014 2:33:27 PM
Here's my understanding, based on decades-old experience so the numbers may have changed over the years:
The impedance of a wire is determined by its dimensions, what other conductors are nearby, the distance to those conductors, and what material is used for insulation.  On PC boards, a wire over a ground plane gives you 50 Ohms with a reasonable thickness of the insulating layer.  You could increase the impedance by using a thicker insulating layer, but then you have a thicker board.
For USB and CAN, the dimensions of the twisted pair and insulation type and thickness give you the 90-120 Ohms.
Coaxial cable typically gives you 50-75 Ohms.
Being off by a few percent doesn't matter.  An impedance mismatch gives you reflections, but if the mismatch is small the reflections are small compared to the signal.
Re: Impedance
krisi   2/12/2014 10:26:20 AM
There is nothing magical about 50, just a compromise number that became a standard...we could had ended up with 75 for example
sukv
Impedance
sukv   2/12/2014 4:17:18 AM
Why exactly are we using 50 ohm impedance ? How we arrived to 50 ?why not 49, 51 etc ?
2: What is the reason behind using 90 ohm impedance for USB and 120 ohm for CAN ?
