svenand
Re: Xilinx System Generator and Zedboard...
svenand   5/31/2014 4:14:31 AM
Hi Raj,
Thanks for the kind words. I have no experience of using Xilinx System Generator and Simulink and no license (I have installed Vivado WebPACK). I may install the 30 days evalution license and give it a try, but no promises.
Sven
RVERMA921
RVERMA921   5/30/2014 1:48:34 PM
Hi,
Your "Zynq Design from Scratch" is really helpful for someone who wants to use MAC as development platform for Zedboard.
Can you please plan to also post something on following?
   - Using Xilinx System Generator Blocks in Simulink to design an example customized IP Block and Generating IP Verilog for Zedboard.
   - Import these IPs into Vivado Design Suite and finally get application working on Zedboard
   - Import these IPs into ISE Design Suite and finally get application working on Zedboard
Thanks
Raj
svenand
Re: Zynq From Scratch
svenand   4/29/2014 4:46:16 AM
Hi,
If you are developing systems or just playing with the Zynq All Programmable SoC you shouldn't miss my blog. It covers almost evrything you want to know about Zynq. So far in 40 chapters and still counting:
Introduction
Changes and updates
Zynq-7000 All Programmable SoC
ZedBoard and other boards
Computer platform and VirtualBox
Installing Ubuntu
Fixing Ubuntu
Installing Vivado
Starting Vivado
Using Vivado
Lab 1. Create a Zynq project
Lab 1. Build a hardware platform
Lab 1. Create a software application
Lab 1. Connect to ZedBoard
Lab 1. Run a software application
Lab 1. Benchmarking ARM Cortex-A9
Lab 2. Adding a GPIO peripheral
Lab 2. Create a custom HDL module
Lab 2. Connect package pins and implement
Lab 2. Create a software application and configure the PL
Lab 2. Debugging a software application
Running Linux from SD card
Installing PetaLinux
Booting PetaLinux
Connect to ZedBoad via ethernet
Rebuilding the PetaLinux kernel image
Running a DHCP server on the host
Running a TFTP server on the host
PetaLinux boot via U-boot
PetaLinux application development
Fixing the host computer
Running NFS servers
VirtualBox seamless mode
Mounting guest file system using sshfs
PetaLinux. Setting up a web server
PetaLinux. Using cgi scripts
PetaLinux. Web enabled application
Convert from VirtualBox to VMware
Running Linaro Ubuntu on ZedBoard
Running Android on ZedBoard
Lab2. Booting from SD card and SPI flash
Happy Zynqing
Sven
Max The Magnificent   3/23/2014 2:38:41 PM
@Sven: I have added 10 more chapters to my blog, describing how to run PetaLinux on the ZedBoard.
Good grief -- slow down man, I can't keep up LOL
svenand
svenand   3/23/2014 5:44:58 AM
Sven
Max The Magnificent   3/19/2014 9:34:36 AM
@Sven: I plan to take a look at the Xillybus solution.
Hi Svewn -- if you keep me up to date with developments, I'll write the occasional blog passing the news along.
svenand
svenand   3/19/2014 9:28:52 AM
Yes, I plan to take a look at the Xillybus solution. Just have to finish a few other things first.
Sven
LVRUFFINO
Zynq From Scratch
LVRUFFINO   3/17/2014 11:50:58 AM
Thamk you for great series. Could you please include suggestions and How-To's for using the Zync device with the Xillybus FIFO interface architecture?
svenand
Re: Thanks
svenand   3/12/2014 2:28:06 AM
You just have to rembember two web addresses:
www.fpgafromscratch.com
www.zynqfromscratch.com
They will take you to the start of my FPGA and ZYNQ blogs.
Sven
jorgemendez
Thanks
jorgemendez   3/11/2014 8:22:46 PM
Hi, thanks for posting this here, I never came aware of your blog and this new series you are introducing sounds great. I'll try to catch it up.  -Juan
Crusty1
squirrelwhispher
David_Ashton_EC
David_Ashton_EC
Jayna Sheats
RoweBots1
bwalker970
Sang-Yun
