VictorRBlake
Contradictory report ?
VictorRBlake   8/1/2014 9:25:38 AM
A recent report from Dell Oro Group seems to contradict the findings of this report, stating that the market for Ethernet ports and services continues to grow. While the distribution of sales may be declining, I think the premise of the article is wrong. The premise is that with the cloud, Ethernet switch market sales will decline. While the efficiencies of the cloud could reduce the # of Ethernet ports sold versus an enterprise data center implementation, that doesn't consider the growing number of diverse cloud services enterprises are consuming. It also doesn't touch the desktop which has always dominated enterprise network purchase. Although the loss of many enterprise datacenters will be a reduction in some Ethernet port sales, those will be made up with the need for greater metro e service needs (higher port speeds) to GET TO and FROM the cloud.
Post It
Re: 25, 40, 50G?
Post It   5/3/2014 8:40:09 AM
25G is a per channel/Lane protocol which is being driven by InfiniBand (EDR), Ethernet (100G 4x25) and Fibre Channel QSFP28.  There is quite a bit of development work being done today across all 3 standards.   It is anyone's guess what the adoption rate and cost will look like.  This development willl likely fuel the need for many new intermediaries to allow 25G switch equipment to efficiently interop with existing servers and storage.  Additionally, there are still many signal integrity challenges related to development and deployment of the 25G datacom architecture.
Re: 25, 40, 50G?
Bert22306   5/2/2014 4:32:20 PM
Until you try streaming 4K content over WiFi
That shouldn't be a problem either. WiFi 802.11n goes up to 600 Mb/s in the 5 GHz band (although ours tops out at 270 Mb/s), which should be enough even for 4K with H.264 compression, and certainly enough for 4K with H.265 compression (which theoretically won't require much more bit rate than HD using H.262 compression, say on the order of 25 Mb/s for 60p). And now WiFi 802.11ad is moving up to the 60 GHz band, for up to 7 Gb/s capacity.
tb100
Re: 25, 40, 50G?
tb100   5/2/2014 4:26:40 PM
I haven't heard of 25Gig Ethernet, so I asume the 25Gig is for Inifiband, which is used with some storage switches (Infiniband also has 2.5Gig).
As mentioned, the other place you see 25G is 4x25Gig (100Gig, either 4 separate fibers or four mulitplexed frequencies), but I don't think that would show up in the chart as 25G.
The reason you don't see too much of 100Gig at one frequency (called coherent 100Gig), is cost. But, as with all things in the electronics industry, costs go down in time as they integrate more and can produce in volume.
Re: 25, 40, 50G?
krisi   5/2/2014 12:02:40 PM
what was teh stronghold at 2.5Gb/s caused by? not by semiconductor devices...I designed 10 Gb/s ICs 10 years ago and 40 Gb/s start-up were starting at that time too
Re: 25, 40, 50G?
krisi   5/2/2014 12:00:44 PM
I agree, 4k TV will happen in 15 years...but who cares?...it is a very increamental improvement that will take very long time to sell, spatial resolutionis limuted by your eyes afterall...we need to get a sense of smell and touch in the living room, that would be something interesting to write about
TanjB
Re: 25, 40, 50G?
TanjB   5/2/2014 11:55:35 AM
4k in consumer space is passed around in compressed (and encrypted, IP controlled) forms.  Probably won't exceed 100Mbps.  1080p HDTV is typically less than 20Mbps.
By the time you have enough of these streams flying around the home to be an issue WiFi will have risen to the challenge.  Even today it could handle a couple of streams.
TanjB
Re: 25, 40, 50G?
TanjB   5/2/2014 11:52:03 AM
We are not talking about long lines, that is a whole different market.  The connections between ethernet switches in a DC do not use FDM or other expensive, physically large devices.  Hence the long stall at 2.5Gbps since that was until recently the practical limit on how many bits a semiconductor could modulate or demodulate on one beam.  Now Intel and partners are promising 25 Gbps devices.
Actually, multiple frequencies/colors would be just fine too, if you could meet the cost and packaging limits of an ethernet socket.
tpfj
Re: 25, 40, 50G?
tpfj   5/2/2014 11:47:54 AM
Sorry @krisi, but I humbly disagree. 3D isn't dead either, but that is outside of the scope of this discussion. So you reckon we won't be at 4K in the next decade and a half (assuming that is how long it takes you to get to your next two TV's)?
Re: 25, 40, 50G?
krisi   5/2/2014 11:18:17 AM
why stop at 25Gb/s? the single fiber strand can take much more, why not 100Gb/s?
