<<   <   Page 4 / 5   >   >>
GWEEPs
David Ashton   7/2/2014 5:15:33 PM
I heard the term Gweep back in the old DOS days, but not since then.  I don't think i ever qualified as one.....
Re: VT100? You're just a pup.
MeasurementBlues   7/2/2014 4:12:46 PM
IO programming: that's why some test stations still run Win98 and older versions of Windows and Even DOS. You had direct access to the IO port. that was changed and made much more complex for security reasons or for Microsfot to make more money.
betajet   7/2/2014 4:02:29 PM
Martin wrote: And yet, we work more today than back then. What went wrong?
While some things are indeed a lot easier now -- my favorite example is being able to capture transient events using a digital 'scope -- many things are much harder.  In particular, it's much harder for a CPU to talk to I/O devices.  My favorite example of this is that the PDP-11 Peripherals Handbook has a chapter called "Programming" which covers how to write I/O programs in PDP-11 assembly language using both busy-waiting and interrupts.  The chapter is eight pages long.
Nowadays device-level programmers have to deal with Windows or Linux device drivers, which require understanding thousands of pages of arbitrary complexity, and modern SoCs require hundreds or thousands of lines of initialization code just to get started.
Another example is USB.  If you're using a properly-designed USB device, it's really easy: you just plug it in and it installed as if by magic.  If you're writing the software to implement that magic, it's a nightmare.
MeasurementBlues   7/2/2014 3:37:17 PM
New EE's now do not have a clue on how much easier things are now, compared to back then.
betajet   7/2/2014 3:24:32 PM
The great thing about punch cards is that you can fold them into missiles and launch them using a rubber band.  They're really dangerous: the point is sharp and they'll go quite a ways into acoustic tile ceilings.
Try doing that with a flash drive :-)
RGARVIN640
RGARVIN640   7/2/2014 3:24:08 PM
I don't miss them either, as I paid $350 for my first floppy drive. An Apple II with  147K storage capacity! Woz was the man. New EE's now do not have a clue on how much easier things are now, compared to back then.
MeasurementBlues   7/2/2014 3:12:31 PM
I did use punch cards my freshman year and I don't miss them. I don't miss floppy disks, either.
betajet   7/2/2014 3:04:32 PM
Guinea pigs also go gweep, gweep, gweeeep.  Either that or jeep, jeep, jeeeeeep.
RGARVIN640
RGARVIN640   7/2/2014 3:01:29 PM
You are not old school unless you used punch cards to enter your programs. My first embedded programming was with an Altair 8800(?) toggleing switches. Then got to work with a 6803 system writing assembly language and storing them on the 8 inch floppy!! First system design was a 6502 based cpu, so wrote assembly code on an Apple II computer.
MeasurementBlues   7/2/2014 2:49:43 PM
A few years after graduating, I returned to my fraternity house and  was appalled. There was a TV-100 in  the  second floor landing, connected over an acoustic dialup modem to  the school VAX computer. A great convenience, but it  meant the gweeps had taken over sacred space.
In conjunction with unveiling of EE Timesí Silicon 60 list, journalist & Silicon 60 researcher Peter Clarke hosts a conversation on startups in the electronics industry. One of Silicon Valley's great contributions to the world has been the demonstration of how the application of entrepreneurship and venture capital to electronics and semiconductor hardware can create wealth with developments in semiconductors, displays, design automation, MEMS and across the breadth of hardware developments. But in recent years concerns have been raised that traditional venture capital has turned its back on hardware-related startups in favor of software and Internet applications and services. Panelists from incubators join Peter Clarke in debate.
The LTģ3042 is a high performance low dropout linear ...
The LTģ3752/LT3752-1 are current mode PWM controllers ...
LED lighting is an important feature in todayís and future ...
A laptopís 65-watt adapter can be made 6 times smaller and ...
10:29
