<<   <   Page 13 / 14   >   >>
Re: Analog meters
David Ashton   8/20/2014 4:28:48 PM
@Max...seconds...you used to be able to get 270 degree meters which would be nice for that....any of those in your stash?  They were common in car gauges.
Re: Chimes
Max The Magnificent   8/20/2014 4:27:07 PM
@David: ....or get one of those old "ding-dong" doorbells and fire it up on the hour....
I'm thinking more like on the hour you hear the sound of creaky clockwork turning, and things sliding and graunching and suchlike -- something that goes on and on -- then cumulates in a soft, sweet "ping"
Re: Analog meters
Max The Magnificent   8/20/2014 4:25:18 PM
@David: Are you going to make custom scales for them?
Bet your booty -- it's hard to tell the time when the big dial's faceplate presents values in Ohms and the two medium meters show volts and amps LOL -- watch for my column tomorrow on this...
Re: Chimes
David Ashton   8/20/2014 4:24:01 PM
Re: Analog meters
Max The Magnificent   8/20/2014 4:23:42 PM
@David: I'd stick to a maximum of 12 things on a meter (in this case hours) because otherwise you'll have to get very close to read them easily.
This is something I'm going to have to look at -- in the case on minutes and seconds I'll need to go up to sixty -- but I might have major lines on the graticule every 10 units with minor lines betweeen them for every unit.
Re: Analog meters
Max The Magnificent   8/20/2014 4:21:41 PM
@David: I'd imagine you are going to drive the meters with PWM at a frequency which won't show on the meter ballistics?
That's right -- PWM is the way to go -- in fact I'll be writing a blog on this in a couple of weeks -- explaining how you work with different meters that were originally intended to display voltage, current, resistance -- and different orders of magnitude -- and so forth...
Re: Analog meters
Max The Magnificent   8/20/2014 4:19:22 PM
@David: I was going to suggest a centre-zero meter (I might even have one for you if you want)...
That's very kind of you, but I picked a couple up as part of my "stash" -- now I'm trying to worjk out how to use them. The thing is that, using the MCU to drive it, I can make a regulat meter "look" like a center-zero meter...
zeeglen
Chimes
zeeglen   8/20/2014 4:18:41 PM
Interesting idea, will be nice to see the finished project. Maybe you could find an old GC-1195 (Heathkit clock) on ebay and salvage the "Big Ben" chimes synthesizer board as well as the tic toc.  Or build your own Big Ben sound generator.
Re: Analog meters
Max The Magnificent   8/20/2014 4:17:11 PM
@David: I love the idea of using a metronome-type meter to tick the seconds.
Me too -- that will give it some real visual interest
Re: Very nice!
Max The Magnificent   8/20/2014 4:15:23 PM
@Duane: Now, if you could only include one of these CRT meters...
I have something even better to go on the top -- but I didn't want to give everything away all at once...
