Page 1 / 4   >   >>
Re: Technological Cheshire Cats TCCs
elizabethsimon   5/18/2017 12:01:04 PM
We're using the Intel hex format to program ATmega parts. I wouldn't be suprised if the Arduino uses it under the hood since that's what the Atmel programmer understands.
We also use Motorola S records to program bootloaders on boards that use Motorola/Freescale parts.
I don't see these file formats going away anytime soon.
traneus
traneus   5/17/2017 6:07:06 PM
Max, I'm still using the Intel hex format to program 8051s. The 8051s are part of USB device chips I use to feed data to modern processors. -- also, I was glad to see and converse with you at ESC Boston, PeteTA
DMcCunney
Re: The Ultimate Guide to ASCII Encoding
DMcCunney   5/16/2017 2:23:31 PM
@Max the Magnificent: Due to the fact that IBM sold its computer systems around the world, it had to create multiple versions of EBCDIC. In fact, 57 different national variants were eventually wending their way across the planet.
Heinz 57 varieties?  :-)
Eric is the currrrent maintainer of the Jargon File, which if the canonical listing of hacker jargon.  The entry for EBCDIC is amusing: http://catb.org/~esr/jargon/html/E/EBCDIC.html
I worked in an IBM shop a long time ago and was aware of EBCDIC, but never had to deal with the variants.
I had more fun dealing with "Extended ASCII".  The ASCII spec defined the first 127 characters possible in an 8 bit byte,  The rest were undefined, and vendors rolled their own on what got put there.  The IBM PC used 128-256 for line drawing characters. math symbols and the like, but that range got used for accented national characters as well.  It survives today as code pages, and being sure you are using the right code page to properly display content in a console window.
>Dennis
Max The Magnificent   5/16/2017 2:20:21 PM
@perl_geek: ...I forget the precise details, (the therapy is obviously working)...
Keep taking the dried frog pills (see also curiosity killed the cat and freaky friday)
DMcCunney
DMcCunney   5/16/2017 2:09:29 PM
@Max the Magnificent: Thanks for sharing -- I LOVE this stuff!!!
I thought you would appreciate it.  Eric got a lot of commentary from other old timers in his blog, and had to say "That's good stuff, but I have to draw the line somewhere about what to include in this piece", and drop stuff as not in scope.
There's all sort of fun stuff in the blog commentary that didn't make the cut for the final version.
>Dennis
perl_geek
perl_geek   5/16/2017 12:24:40 PM
A similar sort of technique was used for variable-length records on magnetic tape. Many IBM shops simply used tapes as a way to keep punched cards that wouldn't turn into confetti in the readers, but others had more complicated data structures to transmit. (E.g. invoices with a fixed vendor/buyer part, and a variable number of line items.)
I forget the precise details, (the therapy is obviously working), but essentially the start of the block or record contained a count of how many characters were in the variable part. I seem to recall it also being used in early hard drives, until the simplicity of reading fixed-length blocks and then sorting out the contents with software became obvious.
Max The Magnificent   5/16/2017 10:08:58 AM
@Traneus Rex: ...Their records are delimited by character count, not by record-ending character...
Hi Peter -- thansk for sharing this info -- very interesting -- I love learning the little tricks of the trade they used in ye olden days to save memory and clock cycles -- also, it was great seeing you at ESC Boston -- Max
Max The Magnificent   5/16/2017 10:07:04 AM
@DMcCunney: See also open source advocate Eric S. Raymond's blog post "Things Every Hacker Once Knew" at http://www.catb.org/esr/faqs/things-every-hacker-once-knew/ for more ASCII (and other) information...
Max The Magnificent   5/16/2017 10:00:53 AM
@DMcCunney: ...Note as well that EBCDIC never really got a standard.  There seems to have been several not quite compatible variants in use on different IBM hardware...
I actually mention this in this column -- my exact words were:
Due to the fact that IBM sold its computer systems around the world, it had to create multiple versions of EBCDIC. In fact, 57 different national variants were eventually wending their way across the planet. (A "standard" with 57 variants! You can only imagine how much fun everybody had when transferring files from one country to another).
DMcCunney
DMcCunney   5/15/2017 10:16:46 PM
>Dennis
Page 1 / 4   >   >>
EE Life
Martin Rowe
Test Tool Finds Ethernet Wiring Errors
Martin Rowe
Post a comment
When my house was renovated several years ago, I had the electrician install network outlets in numerous places, then run the LAN cables to a wiring closet. But he didn't document the ends ...
Martin Rowe
Local Electronics Store Supplies Engineers and Hobbyists
Martin Rowe
5 comments
Rochester, N.Y. — Tucked away in this western New York city known for its optics is Goldcrest Electronics, a local store that's supplied businesses and individuals with electronic ...
Martin Rowe
How to Transform a Technology University (Book Review)
Martin Rowe
1 Comment
The Presiding Genius of the Place by Alison Chisolm. WPI, Worcester, Mass., 234 pp., 2016. Engineers love to discuss, and often criticize, engineering education. They often claim ...
Max Maxfield
Aloha from EEWeb
Max Maxfield
Post a comment
Just a few minutes ago as I pen these words, I posted this blog about this month's Cartoon Punchline Competition over on EEWeb.com.
